Страница 4 из 7 ПерваяПервая ... 23456 ... ПоследняяПоследняя
Показано с 31 по 40 из 61
Тема: Ошибка при обновлении.
  1. #31
    22.12.2006
    Тихое зимовье
    186
    Открываю Owen Logic
  2. #32
    Цитата Сообщение от AVit Посмотреть сообщение
    Добрый день, обновил OwenLogic. Он после этого перестал запускаться. Ошибка : Index was outside the bounds of the array.
    2.4.334.0
    System.IndexOutOfRangeException: Index was outside the bounds of the array.
    at System.Windows.Forms.PropertyGrid.SetSelectState(I nt32 state)
    at System.Windows.Forms.PropertyGrid..ctor()
    at Owen.ExternalInterfaces.PropertyGridEx..ctor()
    at ProgramRelayFBD.PresentationLayer.Form1.Initialize Component()
    at ProgramRelayFBD.PresentationLayer.Form1..ctor()
    at ProgramRelayFBD.PresentationLayer.Form1..ctor(Comm andLineParser commandLineParser, FormPresenterFactory presenterFactory, FunctionRepository stCodeElementRepository, IProjectSettingsModelRepository projectSettingsModelRepo, DrawingDocumentRepository drawingDocumentRepo, IDeviceTargetRepository deviceTargetRepo, IDeviceExtensionTargetRepository deviceExtensionTargetRepo, IContainerTemplateRepository containerTemplateRepository, IDescriptionItemRepository descriptionItemRepository, IShowProgrammingViewService showProgrammingViewService, ShowComponentManager showComponentManager, IReadFromFileService readFromFileService, FunctionBlockTemplateRepository stFunctionBlockRepo)
    at DynamicInjectore93f20f56a1d49029dc7cee6c29337ce(Ob ject[] )
    at Ninject.Activation.Providers.StandardProvider.Crea te(IContext context)
    at Ninject.Activation.Context.ResolveInternal(Object scope)
    at Ninject.Activation.Context.Resolve()
    at Ninject.KernelBase.Resolve(IRequest request, Boolean handleMissingBindings)
    at Ninject.KernelBase.Resolve(IRequest request)
    at Ninject.ResolutionExtensions.GetResolutionIterator (IResolutionRoot root, Type service, Func`2 constraint, IEnumerable`1 parameters, Boolean isOptional, Boolean isUnique)
    at Ninject.ResolutionExtensions.Get[T](IResolutionRoot root, IParameter[] parameters)
    at ProgramRelayFBD.Program.Main(String[] args)
    переустановка, деинсталяция и установка не помогает. Runtime 6.0.20 и Microsoft Visual C++ 2015-2022 установлены. Win7x64
    Уточните информацию о системе - скрин из окна "О системе"
    email: soft@owen.ru
  3. #33
    22.12.2006
    Тихое зимовье
    186
    Добрый день! Высылаю:
    Последний раз редактировалось AVit; 07.09.2023 в 12:25. Причина: уточнение
  4. #34
    а если закрыть ВСЕ программы?
    отключить ВСЁ в автозагрузке?
  5. #35
    22.12.2006
    Тихое зимовье
    186
    Думаете проблема только в этом? Когда был сделан скриншот я не запускал OwenLogic.
    Хотя я попробовал и не помогло.
  6. #36
    22.12.2006
    Тихое зимовье
    186
    У техподдержки нет никаких идей?
    Была задачка интересная, хотел реализовать на ПР. Сначала решил проверить возможность реализации в OwenLogic, запускаю, вижу есть обновление. Ну ладно пусть установятся, подождем. И все. Приехали.
    Мне очень не хочется сносить рабочую бесглючную систему и я это не буду делать, что бы только установить OwenLogic на чистую ОС. Лучше реализую все на другом контроллере.
  7. #37
    9,449
    Так напишите в техподдержку, в смысле, тогда и узнаете их идеи! Наверно надо у того и спросить, чьё мнение Вы хотите знать?!
  8. #38
    Постоянно возникает ошибка при открытии проекта. Помогает - закрываю среду и снова открываю. И после этого опять вызываю проект. Открывается. Какая то явно системная ошибка, не связанная с конкретным проектом.
  9. #39
    Скорее всего, по умолчанию стоит открытие более низкой версией. Открывайте нужную версию, а потом уже открывайте проект.
  10. #40
    Цитата Сообщение от novovek.it Посмотреть сообщение
    Здравствуйте.
    Была необходимость переустановить систему. Установил WIndows 11 22621.1992
    И теперь не могу установить последнюю версию OwenLogic. Сейчас пользуюсь версией 2.1.316. Другие не ставятся.
    Перепробовал разные варианты. Но успеха это не принесло. Получаю ошибку
    RunTime Error (at 22:283):
    Out Of Range.
    v2.0.50727 2.0.50727.4927
    v3.0 3.0.30729.4926
    Windows Communication Foundation 3.0.4506.4926
    Windows Presentation Foundation 3.0.6920.4902
    v3.5 3.5.30729.4926
    Client 4.8.09032
    Full 4.8.09032
    Client 4.0.0.0
    Что это за ошибка. Как её исправить. Что то я не доустанавливал. Или наоборот много уже чего наставил. Не понятно.
    На windows 10 была установлена версия 2.3.328. проблем не было. Всё работало.
    Установил на windows 10 64bit версию 2.3.328. Установилась без проблем. Определила что есть обновление до версии 2.3.330. Обновил. Проблем нет.
    Что то windows 11 не нравится OwenLogic.
    Ошибка исправлена в Owen Logic 2.5.338
    email: soft@owen.ru
  1. Ответов: 4
    Последнее сообщение: 05.02.2020, 17:40
  2. Ошибка W12 ПЧВ 12
    от Ivan.Koryshkin в разделе Приводная техника ОВЕН
    Последнее сообщение: 15.03.2019, 09:38
  3. Пропало питание при обновлении ПО ПР 200
    от Евген84 в разделе Среда программирования OWEN Logic
    Последнее сообщение: 06.06.2017, 16:32
  4. Ошибка!!!
    от Lihoj в разделе Среда программирования OWEN Logic
    Ответов: 34
    Последнее сообщение: 08.04.2016, 21:50
  5. ТРМ-210 и ошибка Err.5
    от КИП в разделе Эксплуатация
    Последнее сообщение: 08.10.2013, 11:07
