Показано с 1 по 10 из 61
Тема: Ошибка при обновлении.
    22.12.2006
    Тихое зимовье
    186
    Добрый день, обновил OwenLogic. Он после этого перестал запускаться. Ошибка : Index was outside the bounds of the array.
    2.4.334.0
    System.IndexOutOfRangeException: Index was outside the bounds of the array.
    at System.Windows.Forms.PropertyGrid.SetSelectState(I nt32 state)
    at System.Windows.Forms.PropertyGrid..ctor()
    at Owen.ExternalInterfaces.PropertyGridEx..ctor()
    at ProgramRelayFBD.PresentationLayer.Form1.Initialize Component()
    at ProgramRelayFBD.PresentationLayer.Form1..ctor()
    at ProgramRelayFBD.PresentationLayer.Form1..ctor(Comm andLineParser commandLineParser, FormPresenterFactory presenterFactory, FunctionRepository stCodeElementRepository, IProjectSettingsModelRepository projectSettingsModelRepo, DrawingDocumentRepository drawingDocumentRepo, IDeviceTargetRepository deviceTargetRepo, IDeviceExtensionTargetRepository deviceExtensionTargetRepo, IContainerTemplateRepository containerTemplateRepository, IDescriptionItemRepository descriptionItemRepository, IShowProgrammingViewService showProgrammingViewService, ShowComponentManager showComponentManager, IReadFromFileService readFromFileService, FunctionBlockTemplateRepository stFunctionBlockRepo)
    at DynamicInjectore93f20f56a1d49029dc7cee6c29337ce(Ob ject[] )
    at Ninject.Activation.Providers.StandardProvider.Crea te(IContext context)
    at Ninject.Activation.Context.ResolveInternal(Object scope)
    at Ninject.Activation.Context.Resolve()
    at Ninject.KernelBase.Resolve(IRequest request, Boolean handleMissingBindings)
    at Ninject.KernelBase.Resolve(IRequest request)
    at Ninject.ResolutionExtensions.GetResolutionIterator (IResolutionRoot root, Type service, Func`2 constraint, IEnumerable`1 parameters, Boolean isOptional, Boolean isUnique)
    at Ninject.ResolutionExtensions.Get[T](IResolutionRoot root, IParameter[] parameters)
    at ProgramRelayFBD.Program.Main(String[] args)
    переустановка, деинсталяция и установка не помогает. Runtime 6.0.20 и Microsoft Visual C++ 2015-2022 установлены. Win7x64
    2.4.334.0
    Открываете проект или сам Owen Logic? Если открываете проект, то пришлите, пожалуйста, его мне на почту - k.korolev@owen.ru.
    email: k.korolev@owen.ru
    22.12.2006
    Тихое зимовье
    186
    Открываю Owen Logic
    2.4.334.0
    Уточните информацию о системе - скрин из окна "О системе"
    Менеджер по продукту | Owen Logic
    email: soft@owen.ru
  1. Ответов: 4
    Последнее сообщение: 05.02.2020, 17:40
  2. Ошибка W12 ПЧВ 12
    от Ivan.Koryshkin в разделе Приводная техника ОВЕН
    Последнее сообщение: 15.03.2019, 09:38
  3. Пропало питание при обновлении ПО ПР 200
    от Евген84 в разделе Среда программирования OWEN Logic
    Последнее сообщение: 06.06.2017, 16:32
  4. Ошибка!!!
    от Lihoj в разделе Среда программирования OWEN Logic
    Ответов: 34
    Последнее сообщение: 08.04.2016, 21:50
  5. ТРМ-210 и ошибка Err.5
    от КИП в разделе Эксплуатация
    Последнее сообщение: 08.10.2013, 11:07
