составил такой код
и получил такой выводКод:... def test_read_param(ol_api, token): tik = datetime.datetime.now() headers = { 'Authorization' : 'Bearer ' + token } data = "{\"ids\":[4337443]}" response = ol_api.post("v1/parameters/last-data",headers=headers,data=data) assert response.status_code == 200, f"Неверный код ответа, получен {response.status_code}" response = response.json() for unit in response: refer = unit["values"] for val in refer: print("прочитали ",val["v"],"\n",tik,"\t",datetime.datetime.now()) def test_save_param(ol_api, token, result): tik = datetime.datetime.now() headers = { 'Authorization' : 'Bearer ' + token } data = "{\"sms_tag\":\"\",\"sms_code\":\"\",\"timeout\":3,\"sync\":false,\"data\":[{\"id\":4337443,\"value\":" + str(result) +"}]}" response = ol_api.post("v1/parameters/write-data",headers=headers,data=data) assert response.status_code == 200, f"Неверный код ответа, получен {response.status_code}" print("записали "+ str(result),"\n",tik,"\t",datetime.datetime.now()) k = 1 if __name__ == "__main__": test_save_param(ol_api(),sec_token, 2) time.sleep(k) test_read_param(ol_api(),sec_token) test_save_param(ol_api(),sec_token, 3) time.sleep(k) test_read_param(ol_api(),sec_token) ...
без паузы между запросами картина следующаязаписали 2
2020-11-24 12:10:10.726314 2020-11-24 12:10:11.973621
прочитали 2.000
2020-11-24 12:10:12.975249 2020-11-24 12:10:13.974617
записали 3
2020-11-24 12:10:13.974871 2020-11-24 12:10:15.260731
прочитали 3.000
2020-11-24 12:10:16.262514 2020-11-24 12:10:17.243913
записали 4
2020-11-24 12:10:17.244163 2020-11-24 12:10:18.692528
прочитали 4.000
2020-11-24 12:10:19.694127 2020-11-24 12:10:20.597240
записали 5
2020-11-24 12:10:20.598487 2020-11-24 12:10:21.841098
прочитали 5.000
2020-11-24 12:10:22.842777 2020-11-24 12:10:23.814789
записали 6
2020-11-24 12:10:23.815012 2020-11-24 12:10:25.181758
прочитали 6.000
2020-11-24 12:10:26.183501 2020-11-24 12:10:27.024241
записали 7
2020-11-24 12:10:27.024927 2020-11-24 12:10:28.148120
прочитали 7.000
2020-11-24 12:10:29.149575 2020-11-24 12:10:30.169654
записали 8
2020-11-24 12:10:30.169954 2020-11-24 12:10:31.445186
прочитали 8.000
2020-11-24 12:10:32.447018 2020-11-24 12:10:33.286865
записали 9
2020-11-24 12:10:33.287118 2020-11-24 12:10:35.116507
прочитали 9.000
2020-11-24 12:10:36.118333 2020-11-24 12:10:37.051470
записали 10
2020-11-24 12:10:37.051757 2020-11-24 12:10:38.239712
прочитали 10.000
2020-11-24 12:10:39.241460 2020-11-24 12:10:40.252901
записали 11
2020-11-24 12:10:40.253126 2020-11-24 12:10:41.374973
прочитали 11.000
2020-11-24 12:10:42.376776 2020-11-24 12:10:43.343120
записали 12
2020-11-24 12:10:43.343873 2020-11-24 12:10:44.548721
прочитали 12.000
2020-11-24 12:10:45.550539 2020-11-24 12:10:46.433549
записали 13
2020-11-24 12:10:46.434118 2020-11-24 12:10:47.660190
прочитали 13.000
2020-11-24 12:10:48.661878 2020-11-24 12:10:49.662488
записали 2
2020-11-24 12:17:41.360882 2020-11-24 12:17:42.587553
прочитали 13.000
2020-11-24 12:17:42.588379 2020-11-24 12:17:43.517711
записали 3
2020-11-24 12:17:43.518318 2020-11-24 12:17:44.878204
прочитали 2.000
2020-11-24 12:17:44.878757 2020-11-24 12:17:45.768300
записали 4
2020-11-24 12:17:45.769321 2020-11-24 12:17:46.972369
прочитали 3.000
2020-11-24 12:17:46.972947 2020-11-24 12:17:48.039915
записали 5
2020-11-24 12:17:48.040774 2020-11-24 12:17:49.753307
прочитали 4.000
2020-11-24 12:17:49.754082 2020-11-24 12:17:50.850080
записали 6
2020-11-24 12:17:50.850398 2020-11-24 12:17:52.231665
прочитали 5.000
2020-11-24 12:17:52.231941 2020-11-24 12:17:53.180357
записали 7
2020-11-24 12:17:53.180997 2020-11-24 12:17:54.479477
прочитали 6.000
2020-11-24 12:17:54.480108 2020-11-24 12:17:55.429537
записали 8
2020-11-24 12:17:55.429803 2020-11-24 12:17:56.666510
прочитали 7.000
2020-11-24 12:17:56.667233 2020-11-24 12:17:57.638818
записали 9
2020-11-24 12:17:57.639497 2020-11-24 12:17:58.834207
прочитали 8.000
2020-11-24 12:17:58.834456 2020-11-24 12:17:59.737217
записали 10
2020-11-24 12:17:59.737495 2020-11-24 12:18:00.843749
прочитали 9.000
2020-11-24 12:18:00.843975 2020-11-24 12:18:01.816344
записали 11
2020-11-24 12:18:01.816566 2020-11-24 12:18:03.000935
прочитали 10.000
2020-11-24 12:18:03.001583 2020-11-24 12:18:03.954371
записали 12
2020-11-24 12:18:03.954935 2020-11-24 12:18:05.199084
прочитали 11.000
2020-11-24 12:18:05.199405 2020-11-24 12:18:06.197832
записали 13
2020-11-24 12:18:06.198444 2020-11-24 12:18:07.341610
прочитали 12.000
2020-11-24 12:18:07.341865 2020-11-24 12:18:08.390938
