Показано с 1 по 10 из 80
Тема: Пид регулятор Codesys
    Цитата Сообщение от Мурат Ахриев Посмотреть сообщение
    Библиотека Util распространяется компанией 3S в компилированном виде, соответственно внутренняя структура функциональных блоков скрыта.
    А почему у меня - в открытом?
    (* PD controller *)
    FUNCTION_BLOCK PID
    VAR_INPUT
    	ACTUAL :REAL;		(* actual value, process variable *)
    	SET_POINT:REAL;	(* desired value, set point *)
    	KP:REAL;				(* proportionality const. (P)*)
    	TN:REAL;				(* reset time (I) in sec *)
    	TV:REAL;				(* rate time, derivative time (D) in sec*)
    	Y_MANUAL:REAL;		(* Y is set to this value as long as MANUAL=TRUE *)
    	Y_OFFSET:REAL;		(* offset for manipulated variable *)
    	Y_MIN:REAL;			(* minimum value for manipulated variable *)
    	Y_MAX:REAL;			(* maximum value for manipulated variable *)
    	MANUAL:BOOL;		(* 	TRUE: manual: Y is not influenced by controller,
    								FALSE: controller determines Y *)
    	RESET:BOOL;			(* reset: set Y output to Y_OFFSET and reset integral part *)
    END_VAR
    VAR_OUTPUT
    	Y:REAL;				(* manipulated variable, set value*)
    	LIMITS_ACTIVE:BOOL:=FALSE;	(* true set value would exceed limits Y_MIN, Y_MAX *)
    	OVERFLOW:BOOL:=FALSE;		(* overflow in integral part *)
    END_VAR
    VAR
    	CLOCK:TON;
    	I: INTEGRAL;
    	D: DERIVATIVE;
    	TMDIFF: DWORD;
    	ERROR: REAL;
    	INIT: BOOL:=TRUE;
    	Y_ADDOFFSET: REAL;
    	KPcopy:REAL;
    	TNcopy:REAL;
    	TVcopy:REAL;
    END_VAR
    IF TN>0 AND KP<> 0 AND (NOT OVERFLOW OR RESET OR MANUAL) THEN
    	ERROR := SET_POINT-ACTUAL;								(* Regeldifferenz *)
    	IF RESET OR MANUAL OR INIT OR (KP<>KPcopy OR TN<>TNcopy OR TV<>TVcopy) THEN							(* Reset oder Handbetrieb *)
    		I(RESET:=TRUE);
    		D(RESET:=TRUE);
    		OVERFLOW:=FALSE;
    		LIMITS_ACTIVE:=FALSE;
    		IF RESET OR INIT THEN
    			Y := Y_OFFSET;
    			INIT:=FALSE;
    			Y_ADDOFFSET := 0;
    		ELSIF MANUAL THEN
    			Y := Y_MANUAL;
    			Y_ADDOFFSET := Y_MANUAL-(Y_OFFSET+KP*(ERROR+I.OUT/TN+D.OUT*TV));
    		ELSE
    			Y_ADDOFFSET := Y - Y_OFFSET - KP*ERROR;
    		END_IF
    		TMDIFF:=0;
    		CLOCK(IN:=FALSE);									(* Timer neu starten *)
    		CLOCK(PT:=t#1h, IN:=TRUE);
    		TNcopy := TN;
    		TVcopy := TV;
    		KPcopy := KP;
    	ELSE
    		CLOCK;												(* Timer abfragen *)
    		TMDIFF:=TIME_TO_DWORD(CLOCK.ET);					(* Zeitdifferenz seit letztem Aufruf *)
    	END_IF;
    	IF TMDIFF>0 THEN
    		D(IN:=ERROR, TM:=TMDIFF, RESET:=FALSE);				(* Differential absch&#228;tzen *)
    		I(IN:=ERROR, TM:=TMDIFF, RESET:=FALSE);				(* Integral absch&#228;tzen *)
    		OVERFLOW := I.OVERFLOW;
    		IF NOT OVERFLOW THEN
    			Y:=Y_OFFSET+KP*(ERROR+I.OUT/TN+D.OUT*TV) + Y_ADDOFFSET;
    			IF Y>1E30 OR Y<-1E30 THEN						(* Overflow steht bevor, darf aber eigentlich nicht passieren *)
    				OVERFLOW:=TRUE;
    			END_IF;
    			IF Y_MAX>Y_MIN AND Y>Y_MAX  THEN				(* Stellwert-Obergrenze &#252;berschritten *)
    				LIMITS_ACTIVE:=TRUE;
    				IF KP<>0 THEN
    					I(IN:=(Y_MAX-Y)*TN/KP,TM:=1000,RESET:=FALSE);		(* Integral korrigieren *)
    				END_IF
    				Y:=Y_MAX;
    			END_IF;
    			IF Y_MAX>Y_MIN AND Y<Y_MIN THEN					(* Stellwert-Untergrenze unterschritten *)
    				IF KP<>0 THEN
    					I(IN:=(Y_MIN-Y)*TN/KP,TM:=1000,RESET:=FALSE);		(* Integral korrigieren *)
    				END_IF
    				Y:=Y_MIN;
    			END_IF;
    		END_IF;
    	ELSE
    		CLOCK(PT:=t#1h,IN:=TRUE);
    	END_IF;
    END_IF;
    Последний раз редактировалось ASo; 26.01.2014 в 13:05.
  1. ПИД регулятор
    от Николаев Андрей в разделе ПЛК (среда CoDeSys V2.3)
    Ответов: 553
    Последнее сообщение: 14.09.2026, 22:51
  2. ПИД регулятор
    от Александр М в разделе ПЛК1хх
    Последнее сообщение: 22.10.2007, 07:47
