Показано с 1 по 3 из 3
Тема: Завис ПЛК
    05.04.2024
    Йошкар-Ола
    12
    По умолчанию Завис ПЛК
    Завис ПЛК 110-60 ms4, не заливается программа, нет связи. Можно ли сбросить до заводских или переустановить систему? Как сбросить до заводских?
    Логи:
    463.174224] m25p80 spi1.2: spi transfer timeout
    [ 463.184088] m25p80 spi1.2: error -110 reading SR
    [ 466.198030] m25p80 spi1.2: spi transfer timeout
    05.04.2024
    Йошкар-Ола
    12
    U-Boot SPL 2014.01 (Sep 20 2018 - 10:10:05)
    U-Boot 2014.01 (Sep 20 2018 - 10:10:05) (OWEN-20180920-5543)
    I2C: ready
    DRAM: 128 MiB
    NAND: 256 MiB
    In: serial
    Out: serial
    Err: serial
    ARM Clock : 400000000 Hz
    DDR Clock : 150000000 Hz
    Net: DaVinci-EMAC
    owen: auth success
    Hit any key to stop autoboot: 0
    NAND read: device 0 offset 0xa0000, size 0x240000
    2359296 bytes read: OK
    ## Booting kernel from Legacy Image at c0700000 ...
    Image Name: Linux-3.4.15-rt25
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 2303776 Bytes = 2.2 MiB
    Load Address: c0008000
    Entry Point: c0008000
    Verifying Checksum ... OK
    Loading Kernel Image ... OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    [ 3.117344] mcp251x spi1.0: MCP251x didn't enter in conf mode after reset
    [ 3.124723] mcp251x spi1.0: probe failed
    [ 3.183588] pruss_uio pruss_uio: platform_get_irq_failed: -6
    system release is 'OWEN-20181015-5562'
    Mounting /dev...OK
    Making device nodes...OK
    Doing /etc/magic... restore is OK
    ldconfig: /lib/libstdc++.so.6.0.19-gdb.py is not an ELF file - it has the wrong magic bytes at the start.
    plc type: PLC110-60K
    loading system clock from stm32...ok
    setting up /root/storage.vol as loop device...done
    checking device /dev/loop0...ok
    repairing /root/storage.vol if needed...done
    usb_mstor: starting gadget...done
    Setting up lo interface
    Setting up hostname 'plc110'
    set eth0 mac address to e4:1e:0a:03:c0:c6 (factory)
    Setting up eth0 interafce
    Setting static IP address 10.0.6.11 on eth0
    Setting up usb0 interafce
    Setting static IP address 192.168.0.10 on usb0
    fw: creating chains
    fw: adding default rules
    fw: creating drop rules
    Adding default gw 10.0.1.1
    No need to update DNS
    Starting dropbear sshd: OK
    /root/retain/rmsync.cfg: correct
    /dev/ttyS0: set as master
    sh: write error: Device or resource busy
    failed to export gpio9
    [rmsync]: using config file:'/root/retain/rmsync.cfg'
    [rmsync]: rs=131072, ra=0xc0515000, rf='/dev/mtd6', i=1, sc=0
    [rmsync]: Notice: use default scan chunk == whole size = 131072
    Starting MasterPLC...[rmsync]: LPVD FIQ is not supported by the system
    05.04.2024
    Йошкар-Ола
    12
    Дальше -
    plc110 login: [ 39.990782] m25p80 spi1.2: spi transfer timeout
    [ 39.999052] m25p80 spi1.2: error -110 reading SR
    [ 46.002644] m25p80 spi1.2: spi transfer timeout
    [ 46.967888] m25p80 spi1.2: error -110 reading SR
    [ 49.971990] m25p80 spi1.2: spi transfer timeout
    [ 49.984522] m25p80 spi1.2: error -110 reading SR
    [ 54.982852] m25p80 spi1.2: spi transfer timeout
    [ 54.990751] m25p80 spi1.2: error -110 reading SR
    [ 64.986783] m25p80 spi1.2: spi transfer timeout
    [ 64.995809] m25p80 spi1.2: error -110 reading SR
  1. Завис MasterSCADA под Windows 10
    от yurgin_757 в разделе Master SCADA 3
    Последнее сообщение: 06.05.2024, 13:55
  2. ПЛК63 завис
    от artyom444 в разделе ПЛК63/73
    Ответов: 21
    Последнее сообщение: 28.03.2023, 18:55
  3. ПЛК 150 ам завис все мигает
    от Victor N. в разделе Эксплуатация
    Последнее сообщение: 30.11.2021, 09:03
  4. Завис ПЛК160
    от Brandon_heat_dre в разделе ПЛК1хх
    Последнее сообщение: 21.12.2019, 17:54
  5. ПЛК100 завис намертво
    от саня89 в разделе ПЛК1хх
    Последнее сообщение: 05.09.2017, 13:53
