Показано с 1 по 10 из 33
Тема: Не открывается проект в Codesys 3.5
    По умолчанию Не открывается проект в Codesys 3.5
    Не удается выгрузить проект с СПК107. Судя по ошибкам не хватает библиотек.
    Через библиотеку не могу не обновить, не загрузить, рядом с ними "!". Где взять эти библиотеки?! Ошибки указал все снизу:
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#IoDrvModbus'. (Reason: The placeholder library 'IoDrvModbus' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElems'. (Reason: The placeholder library 'System_VisuElems' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElemMeter'. (Reason: The placeholder library 'System_VisuElemMeter' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElemsSpecialControls'. (Reason: The placeholder library 'System_VisuElemsSpecialControls' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElemsWinControls'. (Reason: The placeholder library 'System_VisuElemsWinControls' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElemTextEditor'. (Reason: The placeholder library 'System_VisuElemTextEditor' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElemTrace'. (Reason: The placeholder library 'System_VisuElemTrace' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuNativeControl'. (Reason: The placeholder library 'System_VisuNativeControl' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElemsAlarm'. (Reason: The placeholder library 'System_VisuElemsAlarm' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElemCamDisplayer'. (Reason: The placeholder library 'System_VisuElemCamDisplayer' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElem3DPath'. (Reason: The placeholder library 'System_VisuElem3DPath' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#System_VisuElemsDateTime'. (Reason: The placeholder library 'System_VisuElemsDateTime' could not be resolved.)
    [ERROR] ___1_________: Library Manager [Device: Plc Logic: Application]: Could not open library '#system_visuinputs'. (Reason: The placeholder library 'system_visuinputs' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElems'. (Reason: The placeholder library 'System_VisuElems' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemMeter'. (Reason: The placeholder library 'System_VisuElemMeter' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemsSpecialControls'. (Reason: The placeholder library 'System_VisuElemsSpecialControls' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemsWinControls'. (Reason: The placeholder library 'System_VisuElemsWinControls' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemTextEditor'. (Reason: The placeholder library 'System_VisuElemTextEditor' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemTrace'. (Reason: The placeholder library 'System_VisuElemTrace' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuNativeControl'. (Reason: The placeholder library 'System_VisuNativeControl' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemsAlarm'. (Reason: The placeholder library 'System_VisuElemsAlarm' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemCamDisplayer'. (Reason: The placeholder library 'System_VisuElemCamDisplayer' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElem3DPath'. (Reason: The placeholder library 'System_VisuElem3DPath' could not be resolved.)
    [ERROR] visudialogs, 3.5.8.0 (system): Library Manager: Could not open library '#system_visuinputs'. (Reason: The placeholder library 'system_visuinputs' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElems'. (Reason: The placeholder library 'System_VisuElems' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemMeter'. (Reason: The placeholder library 'System_VisuElemMeter' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemsSpecialControls'. (Reason: The placeholder library 'System_VisuElemsSpecialControls' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemsWinControls'. (Reason: The placeholder library 'System_VisuElemsWinControls' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemTextEditor'. (Reason: The placeholder library 'System_VisuElemTextEditor' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemTrace'. (Reason: The placeholder library 'System_VisuElemTrace' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuNativeControl'. (Reason: The placeholder library 'System_VisuNativeControl' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemsAlarm'. (Reason: The placeholder library 'System_VisuElemsAlarm' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemCamDisplayer'. (Reason: The placeholder library 'System_VisuElemCamDisplayer' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElem3DPath'. (Reason: The placeholder library 'System_VisuElem3DPath' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#System_VisuElemsDateTime'. (Reason: The placeholder library 'System_VisuElemsDateTime' could not be resolved.)
    [ERROR] visuusermgmt, 3.5.8.0 (system): Library Manager: Could not open library '#system_visuinputs'. (Reason: The placeholder library 'system_visuinputs' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElems'. (Reason: The placeholder library 'System_VisuElems' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElemMeter'. (Reason: The placeholder library 'System_VisuElemMeter' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElemsSpecialControls'. (Reason: The placeholder library 'System_VisuElemsSpecialControls' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElemsWinControls'. (Reason: The placeholder library 'System_VisuElemsWinControls' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElemTextEditor'. (Reason: The placeholder library 'System_VisuElemTextEditor' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElemTrace'. (Reason: The placeholder library 'System_VisuElemTrace' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuNativeControl'. (Reason: The placeholder library 'System_VisuNativeControl' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElemsAlarm'. (Reason: The placeholder library 'System_VisuElemsAlarm' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElemCamDisplayer'. (Reason: The placeholder library 'System_VisuElemCamDisplayer' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElem3DPath'. (Reason: The placeholder library 'System_VisuElem3DPath' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#System_VisuElemsDateTime'. (Reason: The placeholder library 'System_VisuElemsDateTime' could not be resolved.)
    [ERROR] ___1_________: Library Manager: Could not open library '#system_visuinputs'. (Reason: The placeholder library 'system_visuinputs' could not be resolved.)
    Я сначала открыл в версии sp5, выдал ошибку, что проект создан в sp8, скачал sp8 и теперь эти ошибки
    Начнем с этого: Проект - Установки проекта - Профиль визуализации - выберите наиболее близкий к SP8 профиль из доступных
    Выбрал SP8, а был SP8 (недоступен). Осталась одна ошибка
    Нажмите правой кнопкой мыши на красный знак вопроса в дереве проекта, используйте команду Обновить устройство и выберите такой же компонент с версией, наиболее близкой к 3.5.8.0.
    Прости, пожалуйста, я не особо пока разбираюсь тут, не могу найти, где знак вопроса в дереве?!где знак вопроса.jpg
    Обновил до 3.5.8.0. Но ошибка не ушла, и при открытии проекта окно вылезает об обновлении компилятора на 3.5.8.0. Также висят ошибки в окне предкомпиляции, так и должно быть?! Проект я так могу редактировать и заливать в СПК107?обновлен.pngпредкомпиляция.jpg
    Нажимайте Отмена.
    Нет. Попробуйте удалить конфигурацию тревог (alarm configuration), а затем добавить и настроить ее заново.
  1. Не открывается проект.
    от KIB52 в разделе СП3хх, СП270
    Последнее сообщение: 14.05.2021, 16:42
  2. Не открывается проект ПР200
    от SokolovS в разделе Программируемые реле
    Последнее сообщение: 24.11.2018, 07:16
  3. Не открывается проект : No map for object `-536873641`
    от Anton Evgenevich в разделе Среда программирования OWEN Logic
    Последнее сообщение: 20.03.2018, 09:22
  4. Не открывается проект
    от IgorIO в разделе ПЛК1хх
    Последнее сообщение: 23.08.2015, 20:42
  5. Не открывается проект
    от shide в разделе ПЛК1хх
    Последнее сообщение: 29.10.2009, 13:43
