Показано с 1 по 10 из 11
Тема: How to change IP address on ПЛК150
    16.08.2014
    St. Petersburg, Russia
    8
    По умолчанию How to change IP address on ПЛК150
    I have a few of these ПЛК150, and now I need to change IP address on some of them, but how to do that?
    It looks like there is a web interface on the ПЛК150 that may be the place to do this kind of stuff, but it demand username and password and I can't guess what to use here.
    Sorry but I do not read Russian that well so to read through all the documentation is a huge workload for me, so if any can point me to where I can find info about this it would be nice.
    Regards
    13,406
    Standart IP Address PLC150 - 10.0.6.10 mask 255.255.0.0
    Change IP - set IP on PC 10.0.6.1 mask 255.255.0.0
    Install Target, plug PC to PLC (cross cable) (http://www.owen.ru/uploads/re_plc150_1686.pdf) page 28-30 - Online - Login
    Resource - PLC Browser - ?
    SetIP, SetMask, SetGate and more......
    16.08.2014
    8
    Thanks, that works, I manage to change the IP address, but when the PLC powers up again the old IP address is back, is there any way to store the settings permanently in the PLC?
    13,406
    k2teknik required reboot PLC or shutdown before battery discharge.
    online translator will help you much in the study user manual
    Последний раз редактировалось melky; 16.08.2014 в 22:43.
    16.08.2014
    8
    Ok, now it works.
    First I was trying to make the PLC use DHCP, but that setting is not stored during reboot, when I use static IP address settings things works as expected.
    I was trying to use my ОВЕН КС1 and КС2 cables to make the settings, but non of them can make a connection to the PLC even when I had change the communication settings, a bit strange.
    I am trying but when I copy from the user manual PDF it sometimes only copy partly what I had selected, that is why it is a huge workload for me to read the documentation.
    13,406
    cable КС1 must be connected before turning on the PLC or doing a reset, then the PLC understands that there will be a connection from the CodeSys.
    10.2.4 user manual, but it is more reliable to use Ethernet
    How has brought you to Russia ?
    13.10.2011
    Златоуст
    1,021
    Did you try different viewers? Anyway, you should probably ask the staff for a non-PDF version. Here's one who's active on the forums: http://owen.ru/forum/member.php?u=24
    Последний раз редактировалось Yegor; 17.08.2014 в 19:57.
    16.08.2014
    8
    Thanks, that works for me now.
    A translated version of this chapter is not that clear on this issue, but I will work on a full translation of the manual when I have more time.
    Some twenty years ago I meet a nice girl from Russia in my home country, and as the say "the rest is history".
    16.08.2014
    8
    I had had this issue before with other PDF stuff and the solution was to run the PDF through Abbyy Finereader, and now I had had time to do so, and now I have a more clean version of the manual to translate from.
    13,406
    In twenty years didn't learn Russian?
  1. Установка IP-адреса на ПЛК150
    от figarokj в разделе ПЛК1хх
    Последнее сообщение: 03.12.2015, 10:20
  2. Изменение MAC, IP, Slave address и пр.
    от Александр86 в разделе ПЛК1хх
    Последнее сообщение: 31.03.2014, 13:38
  3. ПЛК150 + codesys via tcp\ip
    от zabep в разделе ПЛК1хх
    Последнее сообщение: 06.01.2013, 09:16
  4. Протокол ОВЕН & Last address
    от Gans в разделе ПЛК1хх
    Последнее сообщение: 11.09.2008, 19:31
  5. Потеря IP и MAC-адресов у ПЛК150
    от Алексей11 в разделе ПЛК1хх
    Последнее сообщение: 16.04.2007, 11:33
