Показано с 11 по 20 из 21
Тема: Проблем с подключением к ПЛК
    /mnt/ufs/root # ps
    PID USER VSZ STAT COMMAND
    1 root 2112 S init
    2 root 0 SW [kthreadd]
    3 root 0 SW [ksoftirqd/0]
    4 root 0 SW [kworker/0:0]
    5 root 0 SW [kworker/u:0]
    6 root 0 SW [posixcputmr/0]
    7 root 0 SW< [khelper]
    8 root 0 SW [kdevtmpfs]
    40 root 0 SW [irq/11-edma]
    41 root 0 SW [irq/12-edma_err]
    42 root 0 SW [irq/93-edma]
    43 root 0 SW [irq/94-edma_err]
    129 root 0 SW [sync_supers]
    131 root 0 SW [bdi-default]
    132 root 0 SW< [kintegrityd]
    134 root 0 SW< [kblockd]
    146 root 0 SW [khubd]
    153 root 0 SW [irq/15-i2c_davi]
    252 root 0 SW [kswapd0]
    253 root 0 SW [fsnotify_mark]
    254 root 0 SW< [crypto]
    310 root 0 SW [mtdblock0]
    315 root 0 SW [mtdblock1]
    320 root 0 SW [mtdblock2]
    325 root 0 SW [mtdblock3]
    330 root 0 SW [mtdblock4]
    335 root 0 SW [mtdblock5]
    343 root 0 SW [ubi_bgt0d]
    344 root 0 SW [kworker/0:1]
    347 root 0 SW [ubi_bgt1d]
    350 root 0 SW [irq/20-spi_davi]
    351 root 0 SW< [spi_davinci.0]
    357 root 0 SW [irq/56-spi_davi]
    358 root 0 SW< [spi_davinci.1]
    368 root 0 SW [mtdblock6]
    382 root 0 SW [irq/59-ohci_hcd]
    386 root 0 SW [irq/158-OHCI ov]
    409 root 0 SW [irq/64-ehrpwmTZ]
    410 root 0 SW [irq/63-ehrpwm_e]
    421 root 0 SW< [deferwq]
    425 root 0 SW [irq/132-powerfa]
    429 root 0 SW< [devfreq_wq]
    430 root 0 SW [irq/53-serial]
    450 root 0 SW [ubifs_bgt1_0]
    459 root 0 SW [irq/58-musb-hdr]
    491 root 0 DW [plc110.stm32]
    494 root 0 DW [plc110.gpio]
    546 root 0 SW< [loop0]
    552 root 0 SW [file-storage]
    569 root 0 SW [irq/33-eth0]
    570 root 0 SW [irq/34-eth0]
    571 root 0 SW [irq/35-eth0]
    572 root 0 SW [irq/36-eth0]
    620 root 2116 S /usr/sbin/dropbear
    632 nobody 2088 S /usr/sbin/dnsmasq -C /etc/dnsmasq.conf
    634 root 2112 S {net_ids.sh} /bin/sh /usr/bin/net_ids.sh -start
    636 root 1980 S sleep 3600
    641 root 3628 S N /usr/sbin/ntpd -c /etc/ntp.conf -g
    644 root 1408 S /sbin/powerfail -f /dev/input/event0
    671 root 1684 S < /root/retain/rmsync -v -v
    672 root 2116 S /sbin/getty -L 115200 ttyS1
    673 root 0 SW [kworker/u:2]
    676 root 3628 S N /usr/sbin/ntpd -c /etc/ntp.conf -g
    681 root 2432 R /usr/sbin/dropbear
    682 root 2432 S -sh
    683 root 2432 R ps
    Цитата Сообщение от Bender Посмотреть сообщение
    /mnt/ufs/root # ps
    1 root 2112 S init
    682 root 2432 S -sh
    683 root 2432 R ps
    Не вижу службы mplc_service.
    Возможно некорректно перепрошился ПЛК.
    Попробуйте перепрошить со следующими указаниями:
    1.Характеристики USB flash-накопителя:
    Объем памяти: не более 8 ГБ;
    Файловая система: FAT или FAT32;
    Размер кластера: стандартный.
    2. Ориентируетесь на время перепрошивки 5 мин.
    Всё получилось. После прошивки эти службы появились, и среда соединилась с контроллером. Большое спасибо.
    Доброго времени. Та-же проблемма, только обновить прошивку в ПЛК никак не получается...И флеш менял и формат... Подскажите как реанимировать, в ПЛК старая версия...5532 и не обновляется ни в какую. MS4D не подключается, похоже не запущена среда исполнения в ПЛК.
    Здравствуйте! Можете предоставить удаленный доступ к ПК (на почту или скайп)? Нужно ещё кабель кс14 (в комплекте с плк идет) подключить к ПК.
    Инженер по продуктам «ПЛК и модули»
    e-mail: i.masterenko@owen.ru | skype: i.masterenko_owen
    Налажу связь по RS-232 debug, свяжусь с вами. Доступ к ПК не проблема.
    Здравствуйте. При отладке программы потерял связь с контроллером и больше не подключается через скаду, но пингуется и через PuTTy заходит. Перепрошивка тоже не идёт (пробывал разные флешки). Версия прошивки 5.562, Scada 1.2.9.17260. Что можно сделать, как восстановить? Работающие процессы:
    plc110 login: login as: root
    Password:
    BusyBox v1.19.3 (2018-10-15 12:09:24 MSK) built-in shell (ash)
    Enter 'help' for a list of built-in commands.
    /mnt/ufs/root # ps
    1 root 2112 S init
    9 root 0 SW [kworker/u:1]
    531 root 0 SW [flush-7:0]
    539 root 0 SW [file-storage]
    556 root 0 SW [irq/33-eth0]
    557 root 0 SW [irq/34-eth0]
    558 root 0 SW [irq/35-eth0]
    559 root 0 SW [irq/36-eth0]
    607 root 2116 S /usr/sbin/dropbear
    619 nobody 2088 S /usr/sbin/dnsmasq -C /etc/dnsmasq.conf
    621 root 2112 S {net_ids.sh} /bin/sh /usr/bin/net_ids.sh -start
    623 root 1980 S sleep 3600
    628 root 3636 S N /usr/sbin/ntpd -c /etc/ntp.conf -g
    631 root 1408 S /sbin/powerfail -f /dev/input/event0
    657 root 1684 S < /root/retain/rmsync -v -v
    679 root 5384 S nginx: master process /root/mplc4/nginx/sbin/nginx -
    680 root 5384 S nginx: worker process
    685 root 3872 S /root/mplc4/mplc_service 31550 /root/mplc4/mplc new
    688 root 3872 S /root/mplc4/mplc_service 31550 /root/mplc4/mplc new
    690 root 2116 S /sbin/getty -L 115200 ttyS1
    712 root 0 SW [flush-ubifs_1_0]
    1260 root 2432 R /usr/sbin/dropbear
    1385 root 2432 S -sh
    1577 root 11144 R /root/mplc4/mplc 7 10
    1578 root 2432 R ps
    /mnt/ufs/root #
    Добрый день. Чтобы не создавать новую тему решил зайти в эту. Вопрос касается смены IP адреса у ПЛК110-60.Р-MS4-3. Выполняю согласно раздела Е.2 руководства по эксплуатации на плк. Подключаюсь к плк через Ethernet, используя Putty.
    Если через Ethernet задаю IP адрес 10.0.6.10, выбираю тип соединения SSH, подключаюсь. Ввожу имя root на запрос login, password игнорирую нажимая Enter, ввожу команду vi /etc/network.conf. Далее начинаются непонятки.
    Согласно руководства: а) нажать клавишу l - ничего данное нажатие не дает;
    b) изменить IP-адрес ПЛК: ну с этим вроде получается , если стирать старую строку и записать новую с новым адресом;
    далее следуют указания которые либо ничего не дают (нажать клавишу ESC) либо выполнить вообще не представляется (ввести команду wq), перезагрузить ПЛК командой reboot.
    Т.е. последние команды связаны с сохранением изменений и перезагрузкой плк, но как это проделать не понятно. Согласно описания не получается.
    Кто менял IP подскажите, пожалуйста, как выполняли эту процедуру?
    13,552
    KIB52 проверьте, есть ли редактор nano ? то есть nano /etc/network.conf
    vi это вообще жесть застарелая. Хотя и в nano есть нюансы... По крайней мере после изменения строки на нужную, жмете Ctrl+X он спросит про измененный буфер, нажать Y и предложит сохранить в файл.
    Здравствуйте. Тот же вопрос, что и у пользователя НиколайG выше в ветке.
    При отладке программы потерял связь с контроллером и больше нет подключения через мастерскаду, пинг контроллера есть, через PuTTy есть доступ. Перепрошивка не идёт (также пробовал разные флешки). Версия прошивки 5.562, Scada 1.2.9.17260. Что можно сделать, как восстановить доступ к контроллеру через мастерскаду?
  1. СПК107 пара проблем
    от Pleonix в разделе СПК1xx (архив)
    Ответов: 12
    Последнее сообщение: 22.02.2017, 12:54
  2. Трудности с подключением пр 110 к ПК.
    от правовед в разделе Программируемые реле
    Последнее сообщение: 16.07.2015, 21:14
  3. Новичок. Проблем с МВА8
    от Коротенко в разделе Мх110
    Последнее сообщение: 17.09.2010, 15:08
  4. Новичок. Проблем с МВА8
    от Коротенко в разделе Эксплуатация
  5. Проблем с ТРМ101-ТР
    от Dmitry B в разделе Эксплуатация
    Последнее сообщение: 05.08.2009, 11:04
