Нашёл пример такой самодиагностики для ПЛК100 из 2013 года
длинная простыня самодиагностика ПЛК100 при включении:
DATAFLASH initialized successful
Welcome to the OWEN program loader 1.3
Kernel found...
Loading kernel...
Reseting...
Checksum OK!
local_status         =d1a1c6b5Load PLC core...
Main oscilator clock=15998976
Processor clock=179988480
Master clock=59996160
Waiting for check power...
Power status OK
at 20080004, s=16
Initialization of Timer0 completed
Module Id=1 found
Module Id=2 found
Module Id=3 found
Module Id=100 found
Module Id=101 found
Module Id=102 found
Module Id=110 found
Module Id=103 found
Module Id=104 fo
Module Id=200 found
Module Id=2000 found
Module Id=2050 found
Module Id=2051 found
Module Id=2052 found
Module Id=2053 found
Module Id=2054 found
Module Id=2055 found
Module Id=2056 found
Module Id=2057 fo2059 found
Module Id=2060 found
Module Id=2061 found
Module Id=2062 found
Module Id=2063 found
Module Id=2064 found
Module Id=2065 found
Module Id=201 found
Module Id=202 found
Module Id=210 found
Module Id=2100 found
Module Id=211 found
Module Id=250 found
Module Id=302 found
Module Id=303 found
Module Id=450 found
Module Id=451 found
Module Id=452 found
Module Id=500 found
Module Id=502 found
Module Id=504 found
Module Id=550 found
Module Id=600 found
Module Id=601 found
Module Id=602 found
Module Id=650 found
Module Id=221 found
Module Id=300 found
Module Id=560 found
Module Id=561 fou
Initialization of Timer5 completed
Initialization of Timer4 completed
USB type code=0
Version 2 detected
Test Complited USB slot is present in PLC!!!
Host is not connected
Start init USB driver !!!
Start init USB - Serial number OK.
Initialization of USB device CDC completed
Begin search and initialize I2C devices
Check for adress 77 ...DEVICE FOUND!
MCP9800 #0 OK!
Check for adress 72 ...FAILED!
Check for adress 4 ...DEVICE FOUND!
PIC lower initialized!
Check for adress 3 ...DEVICE FOUND!
PIC upper initialized!
at 2008003c, s=4
at 20080044, s=4
Read Flash: .at 2008004c, s=4
.at 20080054, s=4
.................at 2008005c, s=4
DATAFLASH READ OK
Flash read takes 3
Start mounting FFS
Flash check takes 2384 ms
It is 0 bad blocks
Mounting of FFS completed!
Mounting takes 241 ms
Total size of filesystem is 3145728 bytes
It is 6077 blocks
It is 67 used blocks
It is 0 bad blocks
Maximum wear level is 108 times
Reset status information.......................
PLC was reset by power!
Last run module Id   =-1743380923
Last post module Id  =-189143393
Total control code   =-563450668
Max cache utilisation =-1093750256
run_level            =185
Run levels stack: 73 ea  0 dd 3e 37 72 78 61 ce 8a 45 dc 58 22 87
at 200800ac, s=28
PLC model MODEL PLC 100
Binary  VERSION 2.10.9
Need Target version 2.10
Compiled: 13:25:45 Sep 25 2009
MAC 6A:77:00:00:58:44
IP 10.0.6.10
GATE 10.0.6.1
MASK 255.255.255.0
PIC upper version is 07
Licence unlimited
No DAC
PIC lower version is 0a
Loading PLC core completed!
Start CoDeSys initialization secuence
CoDeSys.cfg not found RS no modem CoDeSys mode
Special cable detected...
Switch top RS to CoDeSys mode...
Интересующая информация в самом конце
IP 10.0.6.10
GATE 10.0.6.1
MASK 255.255.255.0
Licence unlimited
No DAC
