Owen loader 1.08
CPU:AM1808
DDR Memory:Alliance 128 MB 150 MHz
TEST OK!
NAND
NAND Memory: ID = 194, size = 256M
Valid magicnum, 0x55424CBB, found in block 0x00000006.
Jump to entry point
at: 0xC0000000
Start
Factory setings detected
Found 18 notes in 4 products
SOM01C04 or later detected -> configure RMII clock directly
Auto 485 hardware detected
Waiting for check power...
Power status OK
Initialization of Power control completed
Last run module Id =0
Last post module Id =0
local_status =0
local data #1 =0
local data #2 =0
local data #3 =0
local data #4 =0
Init I2C
Driver for address 77 found
Driver for address 72 found
Begin search and initialize I2C devices
Check for address 77 ...DEVICE FOUND!
MCP9800 #0 OK!
Check for address 72 ...FAILED!
OSC_lev1
OSC_lev2
OSC_lev3
Detect modules
Init group
OSC_ModuleError - can`t read conf!
MRAM init
Init MRAMCheck copies...First OK...Second OK...Copies number: 3 4
Actual copy is 1
USB MSD InitINIT: Init started. Version 1.14.02
INIT: USBH_PreInit!
INIT: USBH_X_Config()
...Init FTDI Stack OK
.OK
FS Init....High-level format ram
Retain mode - save on powerfall
PFM
INIT: Init started. Version 2.13.11
Load PLC core...
Reset status information: PLC was reset by power!
Retain init
$Slave Retain loaded
EEPROM init
No user PRU0 prg => Run def PRU0 prg
No user PRU1 prg => Run def PRU1 prg
Loading PLC core completed!
PLC model MODEL PLC 110-30
▒▒▒▒▒▒ ▒▒ ▒▒▒▒: 2.0
Binary VERSION 1.2.42
Need Target version >= 3.12
Compiled: 14:34:36 Feb 8 2021
STM32 binary version 0
MAC E4:1E:0A:02:05:93
IP 10.0.6.10
GATE 10.0.6.1
MASK 255.255.255.0
Start CoDeSys initialization sequence
No modem.cfg - disable Codesys modem mode
LZS initialization successful
STOP Switch detected-->Project not loaded!
USB HOST Power On
local_status =0
local data #1 =0
local data #2 =0
local data #3 =0
local data #4 =0
