ПЛК 15 года простоял в шкафу почти на улице около трёх лет, шкафчик был обесточен.
Горят "Питание" и "Работа"
выдаёт инфу:
По своему адресу пингуется.Код:DATAFLASH initialized successful <LF> Welcome to the OWEN program loader MAIN_OSCILLATOR_CLOCK=15996928 PCK=199961600 MCK=66653866 Kernel found... Loading kernel... Reseting... Checksum OK! Load PLC core... Main oscilator clock=15996928 Processor clock=199961600 Master clock=66653866 Waiting for check power... Power status OK Initialization of Power control completed at 20080004, s=12 Initialization of Timer0 completed Module Id=1 found Module Id=2 found Module Id=3 found Module Id=103 found Module Id=104 found Module Id=120 found Module Id=131 found Module Id=190 found Module Id=199 found Module Id=200 found Module Id=2000 found Module Id=2050 found Module Id=2051 found Module Id=2052 found Module Id=2053 found Module Id=2054 found Module Id=2055 found Module Id=2056 found Module Id=2057 found Module Id=2058 found Module Id=2059 found Module Id=2060 found Module Id=2061 found Module Id=2062 found Module Id=2063 found Module Id=2064 found Module Id=2065 found Module Id=201 found Module Id=202 found Module Id=203 found Module Id=210 found Module Id=2100 found Module Id=211 found Module Id=250 found Module Id=302 found Module Id=303 found Module Id=450 found Module Id=451 found Module Id=452 found Module Id=562 found Module Id=570 found Module Id=571 found Module Id=599 found Module Id=600 found Module Id=601 found Module Id=602 found Module Id=650 found Module Id=130 found Module Id=221 found Module Id=300 found Module Id=531 found Module Id=400 found Module Id=402 found Module Id=401 found Initialization of Timer5 completed Initialization of Timer4 completed Test Complited USB slot is present in PLC!!!<LF> Host is not connected<LF> Start init USB driver !!!<LF> Start init USB - Serial number OK. <LF> Initialization of USB device CDC completed Begin search and initialize I2C devices Check for adress 77 ...DEVICE FOUND! MCP9800 #0 OK! Check for adress 72 ...FAILED! Check for adress 6 ...DEVICE FOUND! PIC upper initialized! at 20080038, s=4 Read Flash: .at 20080040, s=4 at 20080048, s=4 . . . . . . . . . . . . . . . . . . . . . . . .at 20080050, s=4 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .. DATAFLASH READ OK <LF> Flash read takes 3914 ms Start mounting FFS Flash check takes 2362 ms It is 1 bad blocks Mounting of FFS completed! Mounting takes 308 ms Total size of filesystem is 3145728 bytes It is 5944 blocks It is 199 used blocks It is 1 bad blocks Maximum wear level is 64 times Reset status information....................... PLC was reset by power! <LF> Last run module Id =302 Last post module Id =2000 Total control code =18 Max cache utilisation =2 local_status =2 run_level =2 Run levels stack: ff 15 ff ff ff 0 0 0 0 0 0 0 0 0 0 0 ................................................ Slave Retain loaded at 20080100, s=28 PLC model MODEL PLC 110-30 <LF> Binary VERSION 2.14.0 <LF> Need Target version 2.10 <LF> Compiled: 14:35:31 Apr 28 2011 MAC 6A:77:00:01:91:B0 <LF> IP 192.168.100.77<LF> GATE 255.255.255.0<LF> MASK 255.255.255.0<LF> PIC upper version is 15<LF> Licence limited to 360 bytes<LF> Loading PLC core completed! <LF> Start CoDeSys initialization secuence Initialization of USB device CDC completed Special cable detected... Switch top RS to CoDeSys mode...
Но я никак не могу подключиться к нему из кодесиса, создаю новый проект, предварительно установив таргет version 2.10
отсюда https://ftp.owen.ru/CoDeSys/PLC_110_...110_PLC160.rar
настройки связи
Результата нет, в обоих случаях.
Что делаю неправильно?
Не в тему: USB тут чтобы дырку в пластике закрыть?
Ответить с цитированием
