Показано с 1 по 1 из 1
Тема: МУ110-8Р Авария при Modbus
Древовидный режим
    По умолчанию МУ110-8Р Авария при Modbus
    Модуль МУ110-8Р
    Все его настройки следующие
    Запросы Modbus-RTU осуществляет Lectus
    13:02:00.345 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:00.352 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:00.356 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:00.366 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:00.504 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:00.511 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:00.515 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:00.526 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:01.004 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:01.012 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:01.016 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:01.027 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:01.504 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:01.511 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:01.515 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:01.525 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:02.005 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:02.012 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:02.016 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:02.027 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:02.503 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:02.510 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:02.516 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:02.526 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:03.005 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:03.014 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:03.018 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:03.029 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:03.503 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:03.510 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:03.515 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:03.525 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:04.003 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:04.011 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:04.015 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:04.025 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:04.503 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:04.510 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:04.516 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:04.525 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:05.004 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:05.012 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:05.016 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:05.027 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:05.503 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:05.510 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:05.516 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:05.526 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:06.004 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:06.011 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:06.015 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:06.025 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:06.504 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:06.512 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:06.516 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:06.528 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:07.004 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:07.011 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:07.015 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:07.026 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    13:02:07.505 [9520] (COM1)Tx: [8] 0A 03 00 00 00 01 85 71
    13:02:07.513 [9520] (COM1)Rx: [7] 0A 03 02 00 00 1D 85
    13:02:07.517 [9520] (COM1)Tx: [8] 0B 03 00 00 00 01 84 A0
    13:02:07.526 [9520] (COM1)Rx: [7] 0B 03 02 00 00 20 45
    По логу видно, что каждую секунду в модуль отправляется 2 запроса и модуль отвечает 2 ответами. Вроде бы все нормально, но собственно у модуля каждую секунду загорается светодиод "Авария" и ту же тухнет, которая собственно сбрасывает выхода на начальное значение, хотя запросы идут исправно. Если поставить в параметр "t.out" значение 2, то эта проблема исчезает. Так же происходит если частоту запросов увеличить(в Lectus ставлю частоту запросов 50мс и до 1мс) и опрашивать 2 модуля с разными сетевыми адресами, то по логам видно что запросы идут нормально, а светодиод "Авария" все равно 1 раз в секунду моргает у обоих модулей.
    Последний раз редактировалось s8vb7; 30.04.2015 в 12:02. Причина: UPD
  1. Подключение ПЛК160 к МУ110-8Р
    от Ильг в разделе ПЛК1хх
    Последнее сообщение: 25.02.2015, 17:36
  2. СПК207 master + МУ110-8Р
    от MrNobody в разделе СПК2xx (архив)
    Ответов: 12
    Последнее сообщение: 15.01.2015, 10:32
  3. МУ110-8Р
    от avp94 в разделе Мх110
    Последнее сообщение: 17.04.2011, 15:30
  4. му110-8р
    от valeriy vm в разделе Помощь Разработчикам
    Последнее сообщение: 03.09.2010, 08:34
