<0>
DATAFLASH initialized successful
Welcome to the OWEN program loader 1.3
Kernel found...
Loading kernel...
Reseting...
Checksum OK!
local_status =1Load PLC core...
Main oscilator clock=15998976
Processor clock=179988480
Master clock=59996160
Waiting for check power...
Power status OK
at 20080004, s=16
Initialization of Timer0 completed
Module Id=1 found
Module Id=2 found
Module Id=3 found
Module Id=100 found
Module Id=101 found
Module Id=102 found
Module Id=103 found
Module Id=104 found
Module Id=106 found
Module Id=107 found
Module Id=200 found
Module Id=2000 found
Module Id=2050 found
Module Id=2051 found
Module Id=2052 found
Module Id=2053 found
Module Id=2054 found
Module Id=2055 found
Module Id=2056 found
Module Id=2057 found
Module Id=2058 found
Module Id=2059 found
Module Id=2060 found
Module Id=2061 found
Module Id=2062 found
Module Id=2063 found
Module Id=2064 found
Module Id=2065 found
Module Id=201 found
Module Id=202 found
Module Id=210 found
Module Id=2100 found
Module Id=211 found
Module Id=250 found
Module Id=302 found
Module Id=303 found
Module Id=450 found
Module Id=451 found
Module Id=452 found
Module Id=500 found
Module Id=502 found
Module Id=504 found
Module Id=550 found
Module Id=600 found
Module Id=601 found
Module Id=602 found
Module Id=650 found
Module Id=700 found
Module Id=701 found
Module Id=702 found
Module Id=703 found
Module Id=704 found
Module Id=221 found
Module Id=300 found
Module Id=561 found
Module Id=400 found
Module Id=402 found
Module Id=401 found
Initialization of Timer5 completed
Initialization of Timer4 completed
Begin search and initialize I2C devices
Check for adress 77 ...DEVICE FOUND!
MCP9800 #0 OK!
Check for adress 72 ...DEVICE FOUND!
MCP9800 #1 OK!
Check for adress 4 ...DEVICE FOUND!
PIC lower initialized!
Check for adress 3 ...DEVICE FOUND!
PIC upper initialized!
at 2008003c, s=4
at 20080044, s=4
Read Flash: .at 2008004c, s=4
at 20080054, s=4
at 2008005c, s=4
.at 20080064, s=4
..................at 2008006c, s=4
DATAFLASH READ OK
Flash read takes 3487 ms
Start mounting FFS
Flash check takes 2684 ms
It is 25 bad blocks
Mounting of FFS completed!
Mounting takes 1300 ms
Total size of filesystem is 3145728 bytes
It is 5658 blocks
It is 461 used blocks
It is 25 bad blocks
Maximum wear level is 654 times
Reset status information.......................
PLC was reset by power!
Last run module Id =100
Last post module Id =101
Total control code =2
Max cache utilisation =1
local_status =1
run_level =2
Run levels stack: ff 15 ff ff ff ff 0 0 0 0 0 0 0 0 0 0
Slave Retain loaded
at 200800bc, s=28
ADC and DAC driver initialized!
PLC model MODEL PLC 150
Binary VERSION 2.10.8
Need Target version 2.10
Compiled: 14:11:48 Sep 21 2009
MAC 0A:06:0A:0A:0A:0A
IP 10.0.6.10
GATE 10.0.6.1
MASK 255.255.255.0
PIC upper version is 07
Licence unlimited
Voltage DAC
PIC lower version is 0e
Loading PLC core completed!
Start CoDeSys initialization secuence
CoDeSys.cfg not found RS no modem CoDeSys mode
LZS initialization susesful
Try to open boot project...Loading boot project...at 202a36d8, s=8192
delete 202a36d8
delete 202836d4
InitModule_PID...
**** ERROR: Loading parameter manager info ****Try to parse module Id=1
at 202d8abc, s=12
at 202d8acc, s=32
Try to parse module Id=100
at 202d8af0, s=12
at 202d8b00, s=104
Module Id=100 configuration parsed
Try to parse module Id=101
at 202d8b78, s=12
at 202d8b88, s=128
Module Id=101 configuration parsed
Try to parse module Id=104
at 202d8c18, s=12
at 202d8c28, s=52
Module Id=104 configuration parsed
Try to parse module Id=701
at 202d8c6c, s=12
at 202d8c7c, s=196
Try to parse module Id=107
at 202d8d44, s=12
at 202d8d54, s=144
Module Id=107 configuration parsed
Module Id=701 configuration parsed
Try to parse module Id=702
at 202d8e00, s=12
at 202d8e10, s=196
at 202d8ed8, s=12
at 202d8ee8, s=144
Module Id=702 configuration parsed
Try to parse module Id=700
at 202d8f94, s=12
at 202d8fa4, s=196
at 202d906c, s=12
at 202d907c, s=144
Module Id=700 configuration parsed
at 202d9128, s=12
at 202d9138, s=196
at 202d9200, s=12
at 202d9210, s=144
Try to parse module Id=106
at 202d92bc, s=12
at 202d92cc, s=68
Module Id=106 configuration parsed
at 202d9320, s=12
at 202d9330, s=68
Try to parse module Id=450
at 202d9384, s=12
at 202d9394, s=1128
Try to parse module Id=201
at 202d9800, s=12
at 202d9810, s=2188
Module Id=201 configuration parsed
Try to parse module Id=2000
at 202da0ac, s=12
at 202da0bc, s=380
Try to parse module Id=2004
Not found a apropriate template for a module Id=2004
Try to parse module Id=2003
Not found a apropriate template for a module Id=2003
at 202da23c, s=40
at 202da268, s=3
at 202da270, s=40
at 202da29c, s=3
at 202da2a4, s=40
at 202da2d0, s=3
at 202da2d8, s=40
at 202da304, s=3
at 202da30c, s=40
at 202da338, s=3
at 202da340, s=40
at 202da36c, s=3
at 202da374, s=40
at 202da3a0, s=3
at 202da3a8, s=40
at 202da3d4, s=3
Module Id=2000 configuration parsed
Module Id=450 configuration parsed
Module Id=1 configuration parsed
PollTime=10
at 202da4c0, s=20
at 202da4d8, s=0
at 202da4e0, s=12
at 202da568, s=16
at 202da57c, s=0
at 202da584, s=12
at 202da5dc, s=16
at 202da5f0, s=0
at 202da5f8, s=12
at 202da650, s=16
at 202da664, s=0
at 202da66c, s=12
Initialization of COM1 completed
Configuration parsed succesful
...Boot project loadeddelete 202da7d4
delete 202da7cc
