Так делать можно( на горячую подменять пул и его размер), если нельзя, то как правильно?
Код:CASE( PoolType)OF 0: OWPool( ENABLE := TRUE, Count := 5,(*( SIZEOF( ScanParams)/SIZEOF( ScanParams[ 0])),*) Pool := ADR( ScanParams[ 0]), IsListen := FALSE, ComHandle := Settings.Port); 8..14: OWPool( ENABLE := TRUE, Count := 3, Pool := ADR( ScanParams[ 5]), IsListen := FALSE, ComHandle := Settings.Port); IF( ScanParams[ 5].Complete)THEN PoolType := PoolType OR 1;END_IF IF( ScanParams[ 6].Complete)THEN PoolType := PoolType OR 2;END_IF IF( ScanParams[ 7].Complete)THEN PoolType := PoolType OR 4;END_IF RETURN; 15: OWPool( ENABLE := TRUE, Count := 1, Pool := ADR( ScanParams[ 8]), IsListen := FALSE, ComHandle := Settings.Port); IF( ScanParams[ 8].Complete)THEN PoolType := 0;END_IF RETURN; ELSE task_Main_ERROR( info := 'óïñ...task_Comm_RS_485_1'); RETURN; END_CASE;
Ответить с цитированием
