Показано с 1 по 5 из 5
Тема: Проблемы с СПК107 и ПР200.
    Цитата Сообщение от GoodLuck Посмотреть сообщение
    // 1-й АКБ
    IF bStatusIzmBat = FALSE AND bStatusBat1 = FALSE THEN
    		fbTimer5s1(IN := TRUE, PT := T#10S);
    		iPermission := 1;
    		iBatNumber := 1;
    		IF fbTimer5s1.Q  = FALSE AND fbTimer5s1.ET=fbTimer5s1.PT THEN
    			rBat1 := INT_TO_REAL(iUBat) / 100;
    			bStatusBat1 := TRUE;
    			fbTimer5s1(IN := FALSE, PT := T#0S);
    		ELSE
    			iUBat := 0;
    		END_IF
    END_IF
    // 2-й АКБ
    	IF bStatusBat1 = TRUE AND bStatusBat2 = FALSE THEN
    			fbTimer5s2(IN := TRUE, PT := T#10S);
    			iBatNumber := 2;
    			IF fbTimer5s2.Q  = FALSE AND fbTimer5s2.ET=fbTimer5s2.PT THEN
    				rBat2 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat2 := TRUE;
    				fbTimer5s2(IN := FALSE, PT := T#0S);
    			ELSE
    			iUBat := 0;
    			END_IF
    	END_IF
    // 3-й АКБ
    	IF bStatusBat2 = TRUE AND bStatusBat3 = FALSE THEN
    			fbTimer5s3(IN := TRUE, PT := T#10S);
    			iBatNumber := 3;
    			IF fbTimer5s3.Q = FALSE AND fbTimer5s3.ET=fbTimer5s3.PT THEN
    				rBat3 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat3 := TRUE;
    				fbTimer5s3(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 4-й АКБ
    	IF bStatusBat3 = TRUE AND bStatusBat4 = FALSE THEN
    			fbTimer5s4(IN := TRUE, PT := T#10S);
    			iBatNumber := 4;
    			IF fbTimer5s4.Q = FALSE AND fbTimer5s4.ET=fbTimer5s4.PT THEN
    				rBat4 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat4 := TRUE;
    				fbTimer5s4(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 5-й АКБ
    	IF bStatusBat4 =TRUE AND bStatusBat5 = FALSE THEN
    			fbTimer5s5(IN := TRUE, PT := T#10S);
    			iBatNumber := 5;
    			IF fbTimer5s5.Q = FALSE AND fbTimer5s5.ET=fbTimer5s5.PT THEN
    				rBat5 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat5 := TRUE;
    				fbTimer5s5(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 6-й АКБ
    	IF bStatusBat5 = TRUE AND bStatusBat6 = FALSE THEN
    			fbTimer5s6(IN := TRUE, PT := T#10S);
    			iBatNumber := 6;
    			IF fbTimer5s6.Q = FALSE AND fbTimer5s6.ET=fbTimer5s6.PT THEN
    				rBat6 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat6 := TRUE;
    				fbTimer5s6(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 7-й АКБ
    	IF bStatusBat6 = TRUE AND bStatusBat7 = FALSE THEN
    			fbTimer5s7(IN := TRUE, PT := T#10S);
    			iBatNumber := 7;
    			IF fbTimer5s7.Q = FALSE AND fbTimer5s7.ET=fbTimer5s7.PT THEN
    				rBat7 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat7 := TRUE;
    				fbTimer5s7(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 8-й АКБ
    	IF bStatusBat7 = TRUE AND bStatusBat8 = FALSE THEN
    			fbTimer5s8(IN := TRUE, PT := T#10S);
    			iBatNumber := 8;
    			IF fbTimer5s8.Q = FALSE AND fbTimer5s8.ET=fbTimer5s8.PT THEN
    				rBat8 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat8 := TRUE;
    				fbTimer5s8(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 9-й АКБ
    	IF bStatusBat8 = TRUE AND bStatusBat9 = FALSE THEN
    			fbTimer5s9(IN := TRUE, PT := T#10S);
    			iBatNumber := 9;
    			IF fbTimer5s9.Q = FALSE AND fbTimer5s9.ET=fbTimer5s9.PT THEN
    				rBat9 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat9 := TRUE;
    				fbTimer5s9(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 10-й АКБ
    	IF bStatusBat9 = TRUE AND bStatusBat10 = FALSE THEN
    			fbTimer5s10(IN := TRUE, PT := T#10S);
    			iBatNumber1 := 10;
    			IF fbTimer5s10.Q = FALSE AND fbTimer5s10.ET=fbTimer5s10.PT THEN
    				rBat10 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat10 := TRUE;
    				fbTimer5s10(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 11-й АКБ
    	IF bStatusBat10 = TRUE AND bStatusBat11 = FALSE THEN
    			fbTimer5s11(IN := TRUE, PT := T#10S);
    			iBatNumber1 := 11;
    			IF fbTimer5s11.Q = FALSE AND fbTimer5s11.ET=fbTimer5s11.PT THEN
    				rBat11 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat11 := TRUE;
    				fbTimer5s11(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    		END_IF
    // 12-й АКБ
    	IF bStatusBat11 = TRUE AND bStatusBat12 = FALSE THEN
    			fbTimer5s12(IN := TRUE, PT := T#10S);
    			iBatNumber := 12;
    			IF fbTimer5s12.Q = FALSE AND fbTimer5s12.ET=fbTimer5s12.PT THEN
    				rBat12 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat12 := TRUE;
    				fbTimer5s12(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 13-й АКБ
    	IF bStatusBat12 = TRUE AND bStatusBat13 = FALSE THEN
    			fbTimer5s13(IN := TRUE, PT := T#10S);
    			iBatNumber1 := 13;
    			IF fbTimer5s13.Q = FALSE AND fbTimer5s13.ET=fbTimer5s13.PT THEN
    				rBat13 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat13 := TRUE;
    				fbTimer5s13(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 14-й АКБ
    	IF bStatusBat13 = TRUE AND bStatusBat14 = FALSE THEN
    			fbTimer5s14(IN := TRUE, PT := T#10S);
    			iBatNumber1 := 14;
    			IF fbTimer5s14.Q = FALSE AND fbTimer5s14.ET=fbTimer5s14.PT THEN
    				rBat14 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat14 := TRUE;
    				fbTimer5s14(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 15-й АКБ
    	IF bStatusBat14 = TRUE AND bStatusBat15 = FALSE THEN
    			fbTimer5s15(IN := TRUE, PT := T#10S);
    			iBatNumber1 := 15;
    			IF fbTimer5s15.Q = FALSE AND fbTimer5s15.ET=fbTimer5s15.PT THEN
    				rBat15 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat15 := TRUE;
    				fbTimer5s15(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 16-й АКБ
    	IF bStatusBat15 = TRUE AND bStatusBat16 = FALSE THEN
    			fbTimer5s16(IN := TRUE, PT := T#10S);
    			iBatNumber1 := 16;
    			IF fbTimer5s16.Q = FALSE AND fbTimer5s16.ET=fbTimer5s16.PT THEN
    				rBat16 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat16 := TRUE;
    				fbTimer5s16(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 17-й АКБ
    	IF bStatusBat16 = TRUE AND bStatusBat17 = FALSE THEN
    			fbTimer5s17(IN := TRUE, PT := T#10S);
    			iBatNumber1 := 17;
    			IF fbTimer5s17.Q = FALSE AND fbTimer5s17.ET=fbTimer5s17.PT THEN
    				rBat17 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat17 := TRUE;
    				fbTimer5s17(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    // 18-й АКБ
    	IF bStatusBat17 = TRUE AND bStatusBat18 = FALSE THEN
    			fbTimer5s18(IN := TRUE, PT := T#10S);
    			iBatNumber1 := 18;
    			IF fbTimer5s18.Q = FALSE AND fbTimer5s18.ET=fbTimer5s18.PT THEN
    				rBat18 := INT_TO_REAL(iUBat) / 100;
    				bStatusBat18 := TRUE;
    				fbTimer5s18(IN := FALSE, PT := T#0S);
    			ELSE
    				iUBat := 0;
    			END_IF
    	END_IF
    IF bStatusBat1 AND bStatusBat2 AND bStatusBat3 AND bStatusBat4 AND bStatusBat5 AND bStatusBat6 AND bStatusBat7 AND
    	bStatusBat8 AND bStatusBat9 AND bStatusBat10 AND bStatusBat11 AND bStatusBat12 AND bStatusBat13 AND
    	bStatusBat14 AND bStatusBat15 AND bStatusBat6 AND bStatusBat17 AND bStatusBat18
    THEN
    	bStatusIzmBat := TRUE;
    	//iPermission := 0;
    	fbTimer10m(IN := TRUE, PT := T#10M);
    	iBatNumber := 0;
    	iBatNumber1 := 0;
    	IF fbTimer10m.Q THEN
    		bStatusIzmBat := FALSE;
    		bStatusBat1 := FALSE;
    		bStatusBat2 := FALSE;
    		bStatusBat3 := FALSE;
    		bStatusBat4 := FALSE;
    		bStatusBat5 := FALSE;
    		bStatusBat6 := FALSE;
    		bStatusBat7 := FALSE;
    		bStatusBat8 := FALSE;
    		bStatusBat9 := FALSE;
    		bStatusBat10 := FALSE;
    		bStatusBat11 := FALSE;
    		bStatusBat12 := FALSE;
    		bStatusBat13 := FALSE;
    		bStatusBat14 := FALSE;
    		bStatusBat15 := FALSE;
    		bStatusBat16 := FALSE;
    		bStatusBat17 := FALSE;
    		bStatusBat18 := FALSE;
    		fbTimer10m(IN := FALSE, PT := T#0S);
    	END_IF
    END_IF
    Вообще, для подобного рода задач, лучше использовать CASE.
    При измерении второй АКБ, программа "затыкается", также как и моем варианте. Буду ковырять дальше, но реально пока мыслей здравых нет.
    Таймеры fbTimer5s1 определены как TP?
    Если TON, то конечно, опрашивает только 1-ю АКБ.
    Последний раз редактировалось GoodLuck; 19.06.2020 в 09:15.
    А ларец действительно легко открывался. Действительно по ошибке объявил их как TON. Был уверен, что в объявлении все правильно и ни разу не перепроверил. А копался только в коде.
    Огромное спасибо за помощь!
  1. СПК107: проблемы с загрузкой приложения.
    от Роман Королев в разделе СПК1xx (архив)
    Последнее сообщение: 05.06.2024, 14:20
  2. СПК107 ( visualization ) - Проблемы с сенсорной панелью
    от iAHTOH в разделе Эксплуатация
    Последнее сообщение: 03.02.2021, 12:15
  3. Ответов: 5
    Последнее сообщение: 18.12.2019, 10:03
  4. Проблемы Modbus СПК107 и CoolMasterNet
    от ganz72 в разделе СПК1xx (архив)
    Последнее сообщение: 07.05.2018, 10:57
  5. СПК107 проблемы с сенсорной панелью
    от Kvazar в разделе Сервисное обслуживание приборов ОВЕН
    Последнее сообщение: 27.11.2015, 12:41
