Цитата Сообщение от Дмитрий_Кирсанов Посмотреть сообщение
Не компилируется код: "Ошибка 4010: Несоответствие типов: невозможно преобразовать '9000' в 'TIME'''. Подскажите, пжл, как задать переменную типа TIME?
Скрытый текст:
PHP код:
PROGRAM PLC_PRG
VAR CONSTANT
        Low_Setpoint
INT := 10;
High_Setpoint INT := 15;
END_VAR
VAR
BoilersOn INT;
TimerWAIT;
END_VAR
Moving1
:= 1;
Moving2 := 1;
Moving3 := 2;
Moving4 := 2;
Moving5 := 2;
BoilersOn := 0;
IF (
Is_Boiler1THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler2THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler3THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler4THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler5THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler6THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler7THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler8THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler9THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler10THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler11THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler12THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler13THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler14THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler15THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler16THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler17THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler18THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler19THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler20THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler21THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler22THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler23THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler24THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler25THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler26THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler27THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler28THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler29THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler30THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF (Is_Boiler31THEN
        BoilersOn
:= BoilersOn 1;
END_IF
IF  NOT (Is_Door_OpenTHEN
IF (Curr_Pressure <= Low_Setpoint THEN
IF(BoilersOn <= 10THEN
                         Frequency2
:= 2500;
ELSIF(BoilersOn 10) AND (BoilersOn <= 20THEN
                         Frequency2
:= 5000;
                           ELSE
Frequency2 := 7500;
END_IF
                Frequency1
:= 7500;
Frequency3 := 0;
Frequency4 := 0;
Frequency5 := 0;
ELSIF (Curr_Pressure Low_Setpoint ) AND (Curr_Pressure <= High_Setpoint )  THEN
                Frequency1
:= 7500;
Frequency2 := 0;
Frequency3 := 7500;
Frequency4 := 7500;
Frequency5 := 0;
        ELSE
                IF(
BoilersOn <= 10THEN
                        Frequency5
:= 2500;
                        Frequency5
:= 5000;
                ELSE
Frequency5 := 7500;
END_IF
                Frequency1
:= 0;
Frequency2 := 0;
Frequency3 := 7500;
Frequency4 := 7500;
END_IF
ELSE
B][U]Timer.TIME_IN := 9000;[/U][/B]
Frequency1 := 7500;
Frequency2 := 0;
Frequency3 := 7500;
Frequency4 := 7500;
Frequency5 := 0;
END_IF
PHP код:
FUNCTION_BLOCK WAIT
VAR_INPUT
        TIME_IN
TIME;
END_VAR
VAR_OUTPUT
BOOL := FALSE;
END_VAR
VAR
ZABTP;
END_VAR
    LD        ZAB
.Q
    JMPC    mark
    CAL        ZAB
(IN := FALSE)
LD        TIME_IN
    ST        ZAB
.PT
    CAL        ZAB
(IN := TRUE)
JMP        END
mark
CAL        ZAB
end
LDN        ZAB.Q
    ST        OK
    RET
Читать справку!
TIME константы:
TIME константы
Константы типа TIME в CoDeSys всегда начинаются с префикса "t" или "T" (длинная форма "time" или "TIME") и знака числа "#". Далее следует собственно время, которое может включать дни "d", часы "h", минуты "m", секунды "s" и миллисекунды "ms". Нет необходимости обязательно определять все составляющие времени, но присутствующие поля обязаны следовать именно в таком порядке (d, затем h, затем m, затем s, затем m, затем ms).
Правильные примеры TIME констант в ST:
TIME1 := T#14ms;
TIME1 := T#100S12ms;
(*Старший компонент может выходить за свой предел*)
TIME1 := t#12h34m15s;
Ошибочные примеры:
TIME1 := t#5m68s;
(*Младший компонент вышел за предел*)
TIME1 := 15ms;
(*T# iпропущено*)
TIME1 := t#4ms13d;
(*Ошибочная последовательность*)
См. также:
Типы данных Time Data
По этому должно быть
Timer.TIME_IN := t#9000ms;
или не "ms", а "s", ведь х.з. в каких единицах у Вас время нужно отсчитывать.
Ведь для ФБ Timer у Вас для входной переменной TIME_IN тип не INT, а TIME.
