Показано с 1 по 10 из 11
Тема: ПЛК-63м
    Ну и чего хочешь услышать ? Творение выкладывай
    Не вопрос !
    Пример взят с пластинки, которая пришла с ПЛК.
    Вот его листинг:
    PROGRAM PLC_PRG
    VAR
    	get1_modbus: MB_RD_HOLD_REGS;
    	get2_modbus: MB_RD_INP_REGS;
    	get3_modbus: MB_RD_HOLD_REGS;
    	Buffer: ARRAY[0..255] OF BYTE;
         	cmpl: BOOL;
    	port_opened:  BYTE := 0;
    	Init: BOOL;
    	Settings:COMSETTINGS;
          	com_num: PORTS:=0;
    	enabl: BOOL;
    	err: INT
    	TimeOut: TIME:=T#50ms;
    	Exception: BYTE;
    	DataSize: WORD;
    	master1: BYTE:= 1;
    	t: DWORD;
    	A: WORD := 0;
    	x: WORD;
    	x1: WORD;
    	x2: WORD;
    	x3: WORD;
    	d:  REAL;
    	ptr_D:POINTER TO BYTE;
    	COM_SERVICE1: COM_SERVICE;
    END_VAR
    t:=t+1;
    IF (t MOD 1000)=0 THEN
    	A := A + 1;
    		IF A > 9999 THEN
    			A := 0;
    		END_IF
    END_IF
    IF port_opened=0 THEN
    		Settings.Port:=com_num;
    		Settings.dwBaudRate:=115200;
    		Settings.byParity:=0;
    		Settings.dwTimeout:=0;
    		Settings.byStopBits:=0;
    		Settings.dwBufferSize:=0;
    		Settings.dwScan:=0;
    END_IF
    COM_SERVICE1(Enable:=(port_opened=0) , Settings:=Settings , Task:=OPEN_TSK  );
    IF COM_SERVICE1.ready THEN
    	port_opened:=2;
    END_IF
    IF port_opened=2 THEN
    CASE master1 OF
    0:
    get1_modbus(
    	Enable:=enabl ,
    	Mode:=MB_ASCII ,
    	DevAddr:=2 ,
    	FirstAddr:=8 ,
    	Quantity:=1,
    	ComHandle:=Settings.Port ,
    	TimeOut:=TimeOut ,
    	Buffer:=Buffer ,
    	Complete=>cmpl ,
    	Exception=>err ,
    	ByteCnt=>DataSize );
    IF cmpl THEN
    	IF err=0 THEN
    		x:=BYTE_TO_WORD(BUFFER[1]) OR SHL(BYTE_TO_WORD(BUFFER[0]),8);
    	END_IF
    	master1:=1;
    END_IF
    1:
    get3_modbus(
    	Enable:=enabl ,
    	Mode:=MB_ASCII ,
    	DevAddr:=2 ,
    	FirstAddr:=10 ,
    	Quantity:=2,
    	TimeOut:=TimeOut ,
    	Buffer:=Buffer ,
    	Complete=>cmpl ,
    	Exception=>err ,
    IF cmpl THEN
    	master1:=2;
    	IF err=0 THEN
    		ptr_D:=ADR(d);
    		ptr_D^:=buffer[1];
    		ptr_D:=ptr_D+1;
    		ptr_D^:=buffer[0];
    		ptr_D:=ptr_D+1;
    		ptr_D^:=buffer[3];
    		ptr_D:=ptr_D+1;
    		ptr_D^:=buffer[2];
    	END_IF
    END_IF
    2:
    get2_modbus(
    	Enable:= enabl,
    	Mode:=MB_ASCII ,
    	DevAddr:=2 ,
    	FirstAddr:=12 ,
    	Quantity:=6 ,
    	ComHandle:= Settings.Port,
    	TimeOut:=TimeOut  ,
    	Buffer:=Buffer ,
    	Complete=>cmpl ,
    	Exception=>err ,
    	ByteCnt=> DataSize);
    IF cmpl THEN
    	IF err=0 THEN
    		x1:=BYTE_TO_WORD(BUFFER[1]) OR SHL(BYTE_TO_WORD(BUFFER[0]),8);
    		x2:=BYTE_TO_WORD(BUFFER[5]) OR SHL(BYTE_TO_WORD(BUFFER[4]),8);
    		x3:=BYTE_TO_WORD(BUFFER[9]) OR SHL(BYTE_TO_WORD(BUFFER[8]),8);
    	END_IF
    	master1:=0;
    END_IF
    END_CASE
    IF  enabl = FALSE THEN
     	enabl := TRUE;
    END_IF
    IF  err <> 0 THEN
     	enabl := FALSE;
    END_IF
    END_IF
    Коменты убрал чтобы не мешали иероглифы.
    Вписываю сюда свои данные. Беру только нулевой блок для эксперимента. Хотя и со вторым и третьим вместе, все пакеты запросов и ответов проходят. Остальное рэмю.
    Получается приблизительно как то вот так:
    PROGRAM PLC_PRG
    VAR
    (*	get2_modbus: MB_RD_INP_REGS;
         	cmpl: BOOL;
    	Init: BOOL;
          	com_num: PORTS:=0;
    	enabl: BOOL;
    	err: INT
    	Exception: BYTE;
    	DataSize: WORD;
    	master1: BYTE:= 0; (*Нулевой блок*)
    	t: DWORD;
    	A: WORD := 0;
    	x:WORD;
    	x1: WORD;
    	x2: WORD;
    	x3: WORD;
    	d:  REAL;
    END_VAR
    t:=t+1;
    	A := A + 1;
    		IF A > 9999 THEN
    			A := 0;
    		END_IF
    END_IF
    		Settings.Port:=com_num;(*Можно и 0 поставить*)
    		Settings.dwBaudRate:=9600; (*Скорость*)
    		Settings.byStopBits:=2;(*Стоп биты*)
    		Settings.dwScan:=0;
    END_IF
    	port_opened:=2;
    END_IF
    CASE master1 OF
    0:
    get1_modbus(
    	Enable:=enabl ,
    	Mode:=MB_RTU , (*Можно и 0 поставить*)
    	DevAddr:=8 ,(*Адрес 8*)
    	FirstAddr:=15 ,(*Регистр для считывания (0FH)*)
    	Quantity:=1,(*Один регистр*)
    	TimeOut:=TimeOut ,
    	Buffer:=Buffer ,
    	Complete=>cmpl ,
    	Exception=>err ,
    IF cmpl THEN
    	IF err=0 THEN
    (*Убрал обработку буфера когда пытались определить момент при котором происходит зависание*)
    (*		x:=BYTE_TO_WORD(BUFFER[1]) OR SHL(BYTE_TO_WORD(BUFFER[0]),8);
    так, что остались в работе только FB ModBus*)
    	END_IF
    (*	master1:=1;*)
    END_IF
    (*Отсюда последние два блока отключил, хотя и с ними все запросы и ответы пролетают*)
    1:
    get3_modbus(
    	Enable:=enabl ,
    	Mode:=MB_RTU ,
    	DevAddr:=8 ,
    	FirstAddr:=15 ,
    	Quantity:=2,
    	TimeOut:=TimeOut ,
    	Buffer:=Buffer ,
    	Complete=>cmpl ,
    	Exception=>err ,
    IF cmpl THEN
    	master1:=2;
    	IF err=0 THEN
    		ptr_D:=ADR(d);
    		ptr_D^:=buffer[1];
    		ptr_D:=ptr_D+1;
    		ptr_D^:=buffer[0];
    		ptr_D:=ptr_D+1;
    		ptr_D^:=buffer[3];
    		ptr_D:=ptr_D+1;
    		ptr_D^:=buffer[2];
    	END_IF
    END_IF
    2:
    get2_modbus(
    	Enable:= enabl,
    	Mode:=MB_RTU ,
    	DevAddr:=8 ,
    	FirstAddr:=15 ,
    	Quantity:=6 ,
    	TimeOut:=TimeOut  ,
    	Buffer:=Buffer ,
    	Complete=>cmpl ,
    	Exception=>err ,
    IF cmpl THEN
    	IF err=0 THEN
    	END_IF
    	master1:=0;
    END_IF
    До этого места*)
    END_CASE
     	enabl := TRUE;
    END_IF
    IF  err <> 0 THEN
     	enabl := FALSE;
    END_IF
    END_IF
    Окончательного варианта программы пока нет. Там ещё много чего надо будет написать, а пока экспериментируем и пытаемся понять почему происходит зависание и перезагрузка.
    Последний раз редактировалось Oleg77; 16.09.2018 в 01:10.
