Вот что пишет HyperTerminal:
И еще. О каком контакте речь? Разъем Debug на ПЛК? Кабели пробовал разные. Причем к другим ПЛК с их помощью подключиться удается.Код:DATAFLASH initialized successful Welcome to the OWEN program loader MAIN_OSCILLATOR_CLOCK=15996928 PCK=199961600 MCK=66653866 Kernel found... Loading kernel... Reseting... Checksum OK! Load PLC core... Main oscilator clock=15996928 Processor clock=199961600 Master clock=66653866 Waiting for check power... Power status OK Initialization of Power control completed at 20080004, s=16 Initialization of Timer0 completed Module Id=1 found Module Id=2 found Module Id=3 found Module Id=100 found Module Id=101 found Module Id=1 Module Id=110 found Module Id=103 found Module Id=104 found Module Id=120 found Module Id=200 found Module Id=2000 found Module Id=2050 found Module Id=2051 found Module Id=2052 found Module Id=2053 found Module Id=2054 found Module Id=2055 found Module Id=2056 found Module Id=2057 found Module Id=2058 found Module Id=2059 found Module Id=2060 found Module Id=2061 found Module Id=2062 found Module Id=2063 found Module Id=2064 found Module Id=2065 found Module Id=201 found Module Id=202 found Module Id=2100 found Module Id=250 found Module Id=302 found Module Id=303 found Module Id=450 found Module Id=451 found Module Id=452 found Module Id=500 found Module Id=502 found Module Id=504 found Module Id=550 found Module Id=600 found Module Id=601 found Module Id=602 found Module Id=650 found Module Id=221 found Module Id=300 found Module Id=560 found Module Id=561 found Module Id=400 found Module Id=402 found Module Id=401 found Initialization of Timer5 completed Test Complited USB slot is present in PLC!!! Host is not connected Start init USB driver !!! Initialization of USB device CDC completed Begin search and initialize I2C devices Check for adress 72 ...FAILED! Check for adress 77 ...DEVICE FOUND! MCP9800 #1 OK! Check for adress 4 ...DEVICE FOUND! PIC lower initialized! Check for adress 3 ...DEVICE FOUND! PIC upper initialized! at 2008003c, s=4 at 20080044, s=4 at 2008004c, s=4 at 20080054, s=4 DATAFLASH READ OK Flash read takes 3317 ms Start mounting FFS Flash check takes 1587 ms Mounting of FFS completed! Mounting takes 87 ms Total size of filesystem is 3145728 bytes It is 6082 blocks It is 62 used blocks It is 0 bad blocks Maximum wear level is 12 times Reset status information....................... PLC was reset by power! Last run module Id =100 Last post module Id =100 Total control code =18 Max cache utilisation =1 local_status =1 run_level =1 Run levels stack: ff ff ff ff 0 0 0 0 0 0 0 0 0 0 0 0 ................................................ Slave Retain loaded Initialization of Timer4 completed PLC model MODEL PLC 100 Binary VERSION 2.02.8 Need Target version 2.02 Compiled: 12:54:09 Nov 23 2007 MAC 67:77:00:37:6C:A5 IP 10.0.6.10 GATE 10.0.6.1 MASK 255.255.255.0 Licence unlimited No DAC PIC version is 09 Loading PLC core completed! Start CoDeSys initialization secuence Initialization of USB device CDC completed Special cable detected... Switch top RS to CoDeSys mode...
