Показано с 1 по 10 из 16
Тема: перезагрузка плк150
    По умолчанию перезагрузка плк150
    плк150 после подачи питания начинает циклически перезагружаться
    перепрошить прибор не получается.
    лог загрузки выглядит так:
    Welcome to the OWEN program loader  0  0  0  09c, s=0
    MAIN_OSCILLATOR_CLOCK=16001024
    Initia
    PCK=200012800.............
    MCK=66670933
    Configurati
    Kernel found...ful
    Sla
    Loading kernel...
    ...Boot project
    Reseting... driver ini
    Checksum OK!
    local_status         =1Load PLC core...
    dele
    Binary  VERSION
    Main oscilator clock=16001024eed Target version 2.05202dac
    Processor clock=200012800d: 17:05:53 May 30 2008
    Master clock=66670933
    MAC 66:67:00:0
    Waiting for check power...e
    IP 10.0.6.10
    Power status OKad28
    MAS
    at 20080004, s=16ad34
    P
    Initialization of Timer0 completed
    delete
    Licence limited to 360
    Module Id=1 found
    N
    Module Id=2 foundwer version is 00
    Module Id=3 found
    Loading PL
    Module Id=100 found
    delete  202
    Module Id=101 found initialization sec
    Module Id=102 foundte  202dadb4
    Module Id=
    Checksum OK!
    Module Id=2057 found
    Module Id=2058 found         Try to pars
    Module Id=2059 foundck=16001024
    Module Id=2060 foundProcessor clock=2000
    Module Id=2061 found
    Master
    at
    Module Id=2062 found
    Try to pa
    Module Id=2063 found
    Module Id=2064 found
    at
    at
    Module Id=2065 found
    Init
    Module
    Module Id=201 found parsed
    Module Id=202 founddu
    Try to parse mod
    Module Id=210 found Id=2 found
    at
    Try to parse mo
    Module Id=502 found
    Mod
    a
    Module Id=504 found
    at 20
    Module Id=550 found
    Try to
    Module Id=600 found
    M
    Module Id=601 founds=12
    Module Id=602 found4
    Module Id=650 foundguration parsed
    Module Id=700 foundfound
    Module I
    Module Id=701 foundparsedd
    Module Id=702 found0
    Try to parse modu
    Module Id=703 found=2057 found
    at
    Module Id=704 foundId=2058 fou
    at 202d
    Module Id=221 founde Id=2059
    Try to pa
    Module Id=300 foundule Id=2060 found
    Module Id=561 found12ule Id=2061 found
    Module Id=400 found
    Module Id=2062 f
    M
    Module Id=402 foundration parsed2063 f
    Module Id=401 found
    Mod
    Mounting of FFS completed!
    at 202d927c, s=68Tim
    Mounting takes 652 msR PIC EEPROM READED!
    Total size of filesystem is 3145728 bytesonfiguration parsed
    Begin sea
    It is 5546 blockso parse module Id
    It is 596 used blocks
    at 202d92d0,
    It is 2 bad blocksCE
    at 202d92e0, s
    Maximum wear level is 50 times parse module Id=201
    Chec
    Reset status information.......................
    at 202d975c, s=1340P9800 #1 OK!
    Modul
    PLC was reset by watchdog!edE FOUND!
    Last run module Id   =100ule Id=2000zed!
    Last post module Id  =100 s=12 ...FAILED!
    at
    Total control code   =18 Flash: .
    Try to parse m
    Max cache utilisation =63
    at 200800
    Not found
    local_status         =1r a module Id=2003
    run_level            =15......................
    T
    Run levels stack: ff 14 14 14 14 14 14 14 14 14
    N
    MASK 255.255.255.0te template for a
    PIC upper version is 00level is 39 times
    Licence unlimited
    Try to parse mo
    Current DACion........
    PIC lower version is 0and a apropriate templat
    Loading PLC core completed! by power!
    Start CoDeSys initialization secuence
    at 202da068, s=3odule
    LZS initialization susesful
    Total contr
    at 202da0
    Try to open boot project...le Id=2000 configuration pa
                               Loading boot project..se module Id=2000
    run_level
    at 202d8a44, s=28dule Id=2000 conf
    Try to parse module Id=100
    IP 10.0.6.10
    T
    at 202d8a64, s=12 Id=2000
    MASK 255
    at 202d8a74, s=104at 202da2b4, s=12e
    Module Id=100 configuration parsed
    Licence limite
    Try to parse mo
    Try to parse module Id=101No DAC
    Not found a a
    at 202d8aec, s=12 for a module Id=
    at 202d8afc, s=128mpleted!
    Module Id=101 configuration parseddule Id=2004 secuence
    Try to parse module Id=104e template for a modusful
    at 202d8b8c, s=12
    Try to parse module Id=700004                 Try to
    at 202d8d70, s=12propriate templat
    at 202d8d80, s=192004
    Try to parse module Id=10734, s=12
    at 202da648, s=
    at 202d8e44, s=12
    at 202da674, s=
    at 202d8e54, s=144t 202da67c, s=40
    Module Id=107 configuration parsed
    Module Id=2000 confi
    Module Id=700 configuration parsednfiguration par
    Module Id=450 conf
    Try to parse module Id=700arse module Id=101
    Tr
    at 202d8f00, s=12Id=2202d8aec, s=1
    at 202d8f10, s=192a6c8, s=12c, s=128
    Try to parse module Id=70016
    at 202
    at 202d9090, s=12
    at 202da
    at 202d90a0, s=192
    at 202da8f
    Try to parse module Id=107 202da910, s=0
    a
    at 202d9164, s=12s=12
    a
    at 202d9174, s=144=16
    M
    at 202da98c, s=12
    M
    Co
    Try to parse module Id=106l
    a
    at 202d9220, s=12ect loaded
    a
    at 202d9230, s=68
    Module Id=106 configuration parsed
    at
    delete  202
    Try to parse module Id=106e  202dacbc
    at 202d9284, s=12configuration pa
    at 202d9294, s=68
    de
    delete  202dac
    at 202d9ed4, s=380R=e59ff018
    M
    Try to parse module Id=2003arsed
    Not found a apropriate template for a module Id=2003
    DATAFLASH initialized successful
    at 2
    Try to parse module Id=2004he OWEN program loaderdule
    Not found a apropriate template for a module Id=20045998976
    at 202d9774, s=1340
    PCK=199987200
    at 202da054, s=406662400tion parse
    at 202da080, s=3.
    at 202da088, s=40dule Id=2000
    at 202da0b4, s=3
    Flash che
    Module Id=2000 configuration parsed, s=3
    It is 2 bad blocks
    Try to pa
    Try to parse module Id=2000leted!
    Not found
    at 202da0c8, s=12es 534 msa module
    at 202da0d8, s=380 size of filesyste
    Try to parse module Id=2003to parse module Id=2004
    Not found a apropriate template for a module Id=2003d blocks module Id=2004
    It is 2 bad blocks
    Try to parse module Id=2004level is 46 times
    Not found a apropriate template for a moduion.......0
    at 202da2dc, s=380           =3le Id
    Try to parse module Id=2003s stack: ff 14 45 ff ff ff
    Try to parse module Id=2004..........
    Not found a apropriate template for a module Id=20043
    ADC and DAC driver initialized!
    at 202da45c, s=40
    PLC mo
    at 202da488, s=3figuration parse
    at 202da490, s=40RSION 2.05.7
    at 202da4bc, s=3
    Need Target ver
    Module Id=2000 configuration parsedmpiled: 17:05:53 May 30 20082da0d8,
    Try to parse module Id=200066:67:00:00:81:5DId=2003
    at 202da4d0, s=120.6.10
    Not found
    at 202da4e0, s=380te for a
    MASK 255
    Try to parse modul
    at 202da2dc, s
    Module Id=450 configuration parsed
    Try to parse module Id=2638, s=8192late for a mo
    at 202da6e0, s=12
    at 202da6f0, s=48
    delete  202a3
    Bad channel number at 2 module 6!=5
    No
    InitModule_PID...t
    Module Id=1 configuration parseding parameter manager info ****
    at 202da7fc, s=16
    at 202da45c, s=4
    at 202da810, s=0
    at 202da818, s=12        Try to pa
    at 202da8a0, s=16
    delete  202dacc8
    delete  202dacd4
    delete  202dace0
    delete  202dacf0
    delete  202dacfc
    delete  202dad0c
    delete  202dad18
    delete  202dad28
    delete  202dad34
    delete  202dad44
    delete  202dad50
    delete  202dad60
    delete  202dad6c
    delete  202dad7c
    delete  202dad88
    delete  202dad98
    delete  202dada4
    delete  202dadb4
    delete  202dadc0
    delete  202dadd0
    delete  202daddc
    delete  202dade8
    delete  202dab4c
    прибор несколько дней как вернулся из ремонта с такой же проблемой.
    зав № 10746090202015253
    запустите его с зажатой клавишей пуск. сотрите проект. прошейтесь последней прошивкой, установите последний таргет.
    прошивка последняя доступная на сайте. (2.10.7 (хотя архив 2.10.5 в названии содержит))
    вы похоже не поняли.
    плк перезагружается, я не могу подключиться к нему, ни из кодесис, ни из изи ворк плс
    не могу перепрошить, программа перепрошивки тоже не может подключиться к нему.
    повторюсь, прибор уже был в ремонте с этой же проблемой, приехал на прошлой неделе.
    сегодня с утра должен был быть установлен в установку, с вечера был залит загрузочный проект. проверен, сегодня при попытке запуска - такая петрушка.
    на ПЛК 150 я так понял на прошивку 2.10.7 неправильная ссылка. я скачал 2.10.7 на ftp.
    удерживайте клавишу пуск!
    не выходит каменный цветок....
    правда контроллер удалось перепрошить, с форматированием.
    даже вышел на связь. при попытке залить пустой проект - перегрузился, теперь включается таким образом:
    при подаче питания загораются светодиоды "питание" "работа" "сязь" через 3-4 секунда "работа" и "связь" гаснут.
    все. тишина...
    лог загрузки теперь другой:
    MAIN_OSCILLATOR_CLOCK=15998976
    PCK=199987200
    MCK=66662400
    Kernel found...
    Loading kernel...
    Reseting...
    Checksum OK!
    local_status         =bLoad PLC core...
    Main oscilator clock=15998976
    Processor clock=199987200
    Master clock=66662400
    Power status OK
    at 20080004, s=16
    Module Id=1 found
    Module Id=2 found
    Module Id=3 found
    Module Id=100 found
    Module Id=101 found
    Module Id=102 found
    Module Id=103 found
    Module Id=104 found
    Module Id=106 found
    Module Id=107 found
    Module Id=200 found
    Module Id=2000 found
    Module Id=2050 found
    Module Id=2051 found
    Module Id=2052 found
    Module Id=2053 found
    Module Id=2054 found
    Module Id=2055 found
    Module Id=2056 found
    Module Id=201 found
    Module Id=202 found
    Module Id=210 found
    Module Id=2100 found
    Module Id=211 found
    Module Id=250 found
    Module Id=302 found
    Module Id=303 found
    Module Id=450 found
    Module Id=451 found
    Module Id=452 found
    Module Id=500 found
    Module Id=502 found
    Module Id=504 found
    Module Id=550 found
    Module Id=600 found
    Module Id=601 found
    Module Id=602 found
    Module Id=650 found
    Module Id=700 found
    Module Id=701 found
    Module Id=702 found
    Module Id=703 found
    Module Id=704 found
    Module Id=221 found
    Module Id=300 found
    Module Id=561 found
    Module Id=400 found
    Module Id=402 found
    Module Id=401 found
    Initialization of Timer5 completed
    Initialization of Timer4 completed
    Begin search and initialize I2C devices
    Check for adress 77 ...DEVICE FOUND!
    MCP9800 #0 OK!
    Check for adress 72 ...DEVICE FOUND!
    MCP9800 #1 OK!
    Check for adress 4 ...DEVICE FOUND!
    PIC lower initialized!
    Check for adress 3 ...FAILED!
    Read Flash: .at 2008003c, s=4
    at 20080044, s=4
    .at 2008004c, s=4
    DATAFLASH READ OK
    Flash read ta
    Start mounting FFS
    Flash check takes 1941 ms
    It is 0 bad blocks
    Mounting takes 101 ms
    It is 6131 blocks
    It is 13 used blocks
    It is 0 bad blocks
    Maximum wear level is 12 times
    PLC was reset by power!
    Last run module Id   =-1
    Last post module Id  =-1
    Max cache utilisation =1
    local_status         =b
    run_level            =1
    Run levels stack: ff ff ff ff  0  0  0  0  0  0  0  0  0
    at 2008009c, s=28
    PLC model MODEL PLC 150
    Binary  VERSION 2.10.4
    Need Target version 2.10
    Compiled: 11:04:19 Apr 14 2009
    MAC 66:67:00:00:81:5D
    IP 10.0.6.10
    GATE 10.0.6.1
    MASK 255.255.255.0
    Licence limited to 360 bytes
    No DAC
    PIC lower version is 00
    CoDeSys.cfg not found RS no modem CoDeSys mode
                               **** ERROR: Can not open Checksum file ****
    смущает то что этот контроллер с "М" лицензией....
    Последний раз редактировалось magirus; 13.10.2009 в 14:06.
    у вас версия прошивки 2.10.4 - нужно 2.10.5 и старше.
    но самое главное - нет связи с верхним и нижним Pic - возможно в ремонте из "забыли" прошить.
    это то, что я скачал с сайта...
    http://www.owen.ru/device/88206764 - страница
    http://www.kipshop.ru/CoDeSys/2.10.5/PLC_150_2.10.5.zip - ссылка.
    после прибытия из ремонта контролер работал 2-3 дня...
    Gerkules спасибо, но для меня уже поздно....
    пока возьму из зипа (слава богу есть)
    завтра будем решать вопрос об отправке больного на анализы....
    ЗЫ: обидно, что второй раз одинаковые симптомы.
    проект если нужно могу выложить, но он работает в другом таком контрролере. (кстати у него тоже периодически есть глюк с верхней я так понимаю платой (не горят светодиоды ни один кроме питания.... однако програма работает.)
    буду признателен за версию 2.10.7 на magirus72(дог)list.ru для ПЛК150И М, и ПЛК100Р L.
    Последний раз редактировалось magirus; 13.10.2009 в 19:16.
    03.10.2009
    Самара
    50
    Извените конечно, мне бы тоже последнюю прошивочку....
    Tom1985jerry @ rambler . ru
    Буду примного благодарен))
