Показано с 1 по 3 из 3
Тема: Не могу подключить кодесис к Б/У ПЛК110-24.30.Р.L
    По умолчанию Не могу подключить кодесис к Б/У ПЛК110-24.30.Р.L
    ПЛК 15 года простоял в шкафу почти на улице около трёх лет, шкафчик был обесточен.
    Горят "Питание" и "Работа"
    выдаёт инфу:
    DATAFLASH initialized successful
    <LF>
    Welcome to the OWEN program loader
    MAIN_OSCILLATOR_CLOCK=15996928
    PCK=199961600
    MCK=66653866
    Kernel found...
    Loading kernel...
    Reseting...
    Checksum OK!
    Load PLC core...
    Main oscilator clock=15996928
    Processor clock=199961600
    Master clock=66653866
    Waiting for check power...
    Power status OK
    Initialization of Power control completed
    at 20080004, s=12
    Initialization of Timer0 completed
    Module Id=1 found
    Module Id=2 found
    Module Id=3 found
    Module Id=103 found
    Module Id=104 found
    Module Id=120 found
    Module Id=131 found
    Module Id=190 found
    Module Id=199 found
    Module Id=200 found
    Module Id=2000 found
    Module Id=2050 found
    Module Id=2051 found
    Module Id=2052 found
    Module Id=2053 found
    Module Id=2054 found
    Module Id=2055 found
    Module Id=2056 found
    Module Id=2057 found
    Module Id=2058 found
    Module Id=2059 found
    Module Id=2060 found
    Module Id=2061 found
    Module Id=2062 found
    Module Id=2063 found
    Module Id=2064 found
    Module Id=2065 found
    Module Id=201 found
    Module Id=202 found
    Module Id=203 found
    Module Id=210 found
    Module Id=2100 found
    Module Id=211 found
    Module Id=250 found
    Module Id=302 found
    Module Id=303 found
    Module Id=450 found
    Module Id=451 found
    Module Id=452 found
    Module Id=562 found
    Module Id=570 found
    Module Id=571 found
    Module Id=599 found
    Module Id=600 found
    Module Id=601 found
    Module Id=602 found
    Module Id=650 found
    Module Id=130 found
    Module Id=221 found
    Module Id=300 found
    Module Id=531 found
    Module Id=400 found
    Module Id=402 found
    Module Id=401 found
    Initialization of Timer5 completed
    Initialization of Timer4 completed
    Test Complited USB slot is present in PLC!!!<LF>
    Host is not connected<LF>
    Start init USB driver !!!<LF>
    Start init USB - Serial number OK. <LF>
    Initialization of USB device CDC completed
    Begin search and initialize I2C devices
    Check for adress 77 ...DEVICE FOUND!
    MCP9800 #0 OK!
    Check for adress 72 ...FAILED!
    Check for adress 6 ...DEVICE FOUND!
    PIC upper initialized!
    at 20080038, s=4
    Read Flash: .at 20080040, s=4
    at 20080048, s=4
    .at 20080050, s=4
    DATAFLASH READ OK
    <LF>
    Flash read takes 3914 ms
    Start mounting FFS
    Flash check takes 2362 ms
    It is 1 bad blocks
    Mounting of FFS completed!
    Mounting takes 308 ms
    Total size of filesystem is 3145728 bytes
    It is 5944 blocks
    It is 199 used blocks
    It is 1 bad blocks
    Maximum wear level is 64 times
    Reset status information.......................
    PLC was reset by power!
    <LF>
    Last run module Id   =302
    Last post module Id  =2000
    Total control code   =18
    Max cache utilisation =2
    local_status         =2
    run_level            =2
    Run levels stack: ff 15 ff ff ff  0  0  0  0  0  0  0  0  0  0  0
    Slave Retain loaded
    at 20080100, s=28
    PLC model MODEL PLC 110-30 <LF>
    Binary  VERSION 2.14.0 <LF>
    Need Target version 2.10 <LF>
    Compiled: 14:35:31 Apr 28 2011
    MAC 6A:77:00:01:91:B0 <LF>
    IP 192.168.100.77<LF>
    GATE 255.255.255.0<LF>
    MASK 255.255.255.0<LF>
    PIC upper version is 15<LF>
    Licence limited to 360 bytes<LF>
    Loading PLC core completed!
    <LF>
    Start CoDeSys initialization secuence
    Special cable detected...
    Switch top RS to CoDeSys mode...
    По своему адресу пингуется.
    Но я никак не могу подключиться к нему из кодесиса, создаю новый проект, предварительно установив таргет version 2.10
    отсюда https://ftp.owen.ru/CoDeSys/PLC_110_...110_PLC160.rar
    настройки связи
    Результата нет, в обоих случаях.
    Что делаю неправильно?
    Не в тему: USB тут чтобы дырку в пластике закрыть?
    Последний раз редактировалось BETEP; 05.03.2021 в 17:17.
    Спасибо, по 1200 подключился, странно, почему тогда кодесис мне 2455 подсунул?
    По этому порту по умолчанию к WAGO подключался. Т.е. каждый производитель свой порт придумывает?
    По 232 дебаг, связи так и нет, хотя лог загрузки отдаёт. Это нормально? Перемычка между ногами 4 и 5 в кабеле для чего?
    В шкафу, из которого я его вынул, у контроллера только один из RS485 был задействован.
    Последний раз редактировалось BETEP; 05.03.2021 в 20:13.
    мдя, похоже под вечер глаза замылились.
  1. Не могу подключить МУ110 16К
    от дрю в разделе Мх110
    Последнее сообщение: 15.01.2021, 15:17
  2. Не могу подключить ПР к ПК
    от GladiK в разделе Программируемые реле
    Последнее сообщение: 06.04.2018, 15:59
  3. Не могу подключить МДВВ к ПЛК-150
    от lagoon в разделе ПЛК1хх
    Последнее сообщение: 13.05.2011, 12:50
  4. Ответов: 7
    Последнее сообщение: 09.09.2009, 12:16
  5. Opm ( не могу подключить прибор)
    от незарегистрированный в разделе Сервисное ПО
    Последнее сообщение: 20.06.2008, 20:28
