Страница 72 из 143 ПерваяПервая ... 2262707172737482122 ... ПоследняяПоследняя
Показано с 711 по 720 из 1423
Тема: ПР205
  1. #711
    Добрый день, подскажите причину ошибки
    Operation is not valid due to the current state of the object
    информация из буфера
    2.7.353.0
    System.InvalidOperationException: Operation is not valid due to the current state of the object.
    at ProgramRelayFBD.InfrastructureLayer.Adapters.Conta inersVer2.ParameterDescriptorRepository.EnforceUni queParameterInvariant(ParameterDescriptor parameter)
    at ProgramRelayFBD.InfrastructureLayer.Adapters.Conta inersVer2.ParameterDescriptorRepository.AddParamet erDescriptor(ParameterDescriptor parameterDescriptor)
    at ProgramRelayFBD.ApplicationLayer.ContainersVer2.Bu ildLogicParameterDescriptorsService.BuildByInputVa riableNode(NodeThatDescribeVariable inputVariableNode, IEnumerable`1 referenceFromContainers, IParameterDescriptorRepository parameterDescriptionRepo, Guid variableUniqueId)
    at ProgramRelayFBD.ApplicationLayer.ContainersVer2.Bu ildInputOutputNodesService.BuildAdditionalInputVar iables(IEnumerable`1 additionalVariables, IBuildLogicParameterDescriptorsService buildParameterDescriptorsService, ProgramCode program, IParameterDescriptorRepository parameterNodesRepo, IVariableInfoRepository variableInfoRepository)
    at ProgramRelayFBD.ApplicationLayer.ContainersVer2.Bu ildInputOutputNodesService.BuildFromContainerDescr iption(ContainerDescriptor logicContainerDescriptor, IVariableInfoRepository compilingVariableRepo, IBuildLogicParameterDescriptorsService buildParameterDescriptorsService, ProgramCode program, ContainersVer2Compiler compiler, IParameterDescriptorRepository parameterNodesRepo, IMappingParameterRepository mappingParameterRepo, IGenerateNodeCatalogsService generateNodeCatalogs)
    at ProgramRelayFBD.ApplicationLayer.ContainersVer2.Co ntainersProgramBuilder.BuildLogicContainerDescript orAsync(ProgramCode program, ContainersVer2Compiler compiler, ContainerDescriptor logicContainerDescriptor, IParameterDescriptorRepository parameterDescriptorRepo)
    at ProgramRelayFBD.ApplicationLayer.ContainersVer2.Bu ildCompilerFilesService.BuildProgram(IContainersVe r2BuilderFacade builderFacade, ProgramCode program, ICompiler compiler, IContainerRepository containerRepository, IProgramBuilder programBuilder, ISetupConsistenceData consistencyService, IParameterDescriptorRepository parameterDescriptorRepo)
  2. #712
    Здравствуйте.
    Не планируется ли расширение линейки ПР205? Хотелось бы увидеть модель с 4 транзисторными выходами. Было в планах на нем построить ИТП с двумя КЗР, а реле для них применять не хочется.
  3. #713
    2.7.353.0
    Добрый день. Пришлите, пожалуйста, Ваш проект мне на почту с указанием последовательности действий, после которой наблюдаете эту ошибку.
    email: k.korolev@owen.ru
  4. #714
    Цитата Сообщение от Карбофос Посмотреть сообщение
    Здравствуйте.
    Добрый день, во вложениях планирующиеся модификации:
  5. #715
    Здорово, ждем!
  6. #716
    Все же уточню: примерно когда планируется запуск производства новых модификаций?
  7. #717
    Планируем начинать продажи в ноябре-декабре этого года.
  8. #718
    Пользователь Аватар для yura2507
    07.02.2022
    Нижний Новгород
    27
    Коллеги, здравствуйте!
    Подскажите, есть ли возможность работать с памятью пр205 непосредственно ~%mw12? Спасибо.
  9. #719
    Нет, там даже таких адресов нет.
  10. #720
    Интересный момент произошел сегодня при прошивке ПР205.
    - Обновил OL на версию 2.7.354.0
    - Попытался обновить программу на ПР205 и не смог
    - Прибор перешел в режим логика остановлена. Программа не обновилась. Вышел из режима "логика остановлена" только передернув питание.
    - Как обычно попробовал поменять кучу кабелей, пробовал шить и с компа и с ноутбука, результат один - "логика остановлена"
    - В итоге пробовал прошить из старой версии лоджика - не может обновить внутреннее программное обеспечение.
    - После N попытки обновления программы вылезло
    но после перезагрузки ошибка Retain пропала....
    В итоге теперь лежит непрошиваемая ПР205 (ее прошивал раз 10 до этого всего)
    Ладно, думаю, есть в запасе еще одна ПР205 (совершенно случайно, для другого объекта). Заливаю на столе программу, вроде все норм, отобразился главный экран программы. Отношу на объект меняю ПР205. Подаю питание и вижу на экране "Логика отсутствует". Заливаю прогу повторно уже на объекте и вижу на экране как и с первой ПР205
    Ну думаю еще одна... но секунд через 20 выскочило окошко с прогресс баром и залилась программа. Больше экспериментировать не стал с прошивками.
    Вот и думаю толи ПР205, либо внутренне программное обеспечение глючное.
    Есть способ без сервисного центра прошить ПР205?
    Ответов: 66
  2. Пр205 в новом каталоге
    Ответов: 75
  3. судьба пр205
