плк150 после подачи питания начинает циклически перезагружаться
перепрошить прибор не получается.
лог загрузки выглядит так:
прибор несколько дней как вернулся из ремонта с такой же проблемой.Код:Welcome to the OWEN program loader 0 0 0 09c, s=0
MAIN_OSCILLATOR_CLOCK=16001024
Initia
PCK=200012800.............
MCK=66670933
Configurati
Kernel found...ful
Sla
Loading kernel...
...Boot project
Reseting... driver ini
Checksum OK!
local_status =1Load PLC core...
dele
Binary VERSION
Main oscilator clock=16001024eed Target version 2.05202dac
Processor clock=200012800d: 17:05:53 May 30 2008
Master clock=66670933
MAC 66:67:00:0
Waiting for check power...e
IP 10.0.6.10
Power status OKad28
MAS
at 20080004, s=16ad34
P
Initialization of Timer0 completed
delete
Licence limited to 360
Module Id=1 found
N
Module Id=2 foundwer version is 00
Module Id=3 found
Loading PL
Module Id=100 found
delete 202
Module Id=101 found initialization sec
Module Id=102 foundte 202dadb4
Module Id=
Checksum OK!
Module Id=2057 found
Module Id=2058 found Try to pars
Module Id=2059 foundck=16001024
Module Id=2060 foundProcessor clock=2000
Module Id=2061 found
Master
at
Module Id=2062 found
Try to pa
Module Id=2063 found
Module Id=2064 found
at
at
Module Id=2065 found
Init
Module
Module Id=201 found parsed
Module Id=202 founddu
Try to parse mod
Module Id=210 found Id=2 found
at
Try to parse mo
Module Id=502 found
Mod
a
Module Id=504 found
at 20
Module Id=550 found
Try to
Module Id=600 found
M
Module Id=601 founds=12
Module Id=602 found4
Module Id=650 foundguration parsed
Module Id=700 foundfound
Module I
Module Id=701 foundparsedd
Module Id=702 found0
Try to parse modu
Module Id=703 found=2057 found
at
Module Id=704 foundId=2058 fou
at 202d
Module Id=221 founde Id=2059
Try to pa
Module Id=300 foundule Id=2060 found
Module Id=561 found12ule Id=2061 found
Module Id=400 found
Module Id=2062 f
M
Module Id=402 foundration parsed2063 f
Module Id=401 found
Mod
Mounting of FFS completed!
at 202d927c, s=68Tim
Mounting takes 652 msR PIC EEPROM READED!
Total size of filesystem is 3145728 bytesonfiguration parsed
Begin sea
It is 5546 blockso parse module Id
It is 596 used blocks
at 202d92d0,
It is 2 bad blocksCE
at 202d92e0, s
Maximum wear level is 50 times parse module Id=201
Chec
Reset status information.......................
at 202d975c, s=1340P9800 #1 OK!
Modul
PLC was reset by watchdog!edE FOUND!
Last run module Id =100ule Id=2000zed!
Last post module Id =100 s=12 ...FAILED!
at
Total control code =18 Flash: .
Try to parse m
Max cache utilisation =63
at 200800
Not found
local_status =1r a module Id=2003
run_level =15......................
T
Run levels stack: ff 14 14 14 14 14 14 14 14 14
N
MASK 255.255.255.0te template for a
PIC upper version is 00level is 39 times
Licence unlimited
Try to parse mo
Current DACion........
PIC lower version is 0and a apropriate templat
Loading PLC core completed! by power!
Start CoDeSys initialization secuence
at 202da068, s=3odule
LZS initialization susesful
Total contr
at 202da0
Try to open boot project...le Id=2000 configuration pa
Loading boot project..se module Id=2000
run_level
at 202d8a44, s=28dule Id=2000 conf
Try to parse module Id=100
IP 10.0.6.10
T
at 202d8a64, s=12 Id=2000
MASK 255
at 202d8a74, s=104at 202da2b4, s=12e
Module Id=100 configuration parsed
Licence limite
Try to parse mo
Try to parse module Id=101No DAC
Not found a a
at 202d8aec, s=12 for a module Id=
at 202d8afc, s=128mpleted!
Module Id=101 configuration parseddule Id=2004 secuence
Try to parse module Id=104e template for a modusful
at 202d8b8c, s=12
Try to parse module Id=700004 Try to
at 202d8d70, s=12propriate templat
at 202d8d80, s=192004
Try to parse module Id=10734, s=12
at 202da648, s=
at 202d8e44, s=12
at 202da674, s=
at 202d8e54, s=144t 202da67c, s=40
Module Id=107 configuration parsed
Module Id=2000 confi
Module Id=700 configuration parsednfiguration par
Module Id=450 conf
Try to parse module Id=700arse module Id=101
Tr
at 202d8f00, s=12Id=2202d8aec, s=1
at 202d8f10, s=192a6c8, s=12c, s=128
Try to parse module Id=70016
at 202
at 202d9090, s=12
at 202da
at 202d90a0, s=192
at 202da8f
Try to parse module Id=107 202da910, s=0
a
at 202d9164, s=12s=12
a
at 202d9174, s=144=16
M
at 202da98c, s=12
M
Co
Try to parse module Id=106l
a
at 202d9220, s=12ect loaded
a
at 202d9230, s=68
Module Id=106 configuration parsed
at
delete 202
Try to parse module Id=106e 202dacbc
at 202d9284, s=12configuration pa
at 202d9294, s=68
de
delete 202dac
at 202d9ed4, s=380R=e59ff018
M
Try to parse module Id=2003arsed
Not found a apropriate template for a module Id=2003
DATAFLASH initialized successful
at 2
Try to parse module Id=2004he OWEN program loaderdule
Not found a apropriate template for a module Id=20045998976
at 202d9774, s=1340
PCK=199987200
at 202da054, s=406662400tion parse
at 202da080, s=3.
at 202da088, s=40dule Id=2000
at 202da0b4, s=3
Flash che
Module Id=2000 configuration parsed, s=3
It is 2 bad blocks
Try to pa
Try to parse module Id=2000leted!
Not found
at 202da0c8, s=12es 534 msa module
at 202da0d8, s=380 size of filesyste
Try to parse module Id=2003to parse module Id=2004
Not found a apropriate template for a module Id=2003d blocks module Id=2004
It is 2 bad blocks
Try to parse module Id=2004level is 46 times
Not found a apropriate template for a moduion.......0
at 202da2dc, s=380 =3le Id
Try to parse module Id=2003s stack: ff 14 45 ff ff ff
Try to parse module Id=2004..........
Not found a apropriate template for a module Id=20043
ADC and DAC driver initialized!
at 202da45c, s=40
PLC mo
at 202da488, s=3figuration parse
at 202da490, s=40RSION 2.05.7
at 202da4bc, s=3
Need Target ver
Module Id=2000 configuration parsedmpiled: 17:05:53 May 30 20082da0d8,
Try to parse module Id=200066:67:00:00:81:5DId=2003
at 202da4d0, s=120.6.10
Not found
at 202da4e0, s=380te for a
MASK 255
Try to parse modul
at 202da2dc, s
Module Id=450 configuration parsed
Try to parse module Id=2638, s=8192late for a mo
at 202da6e0, s=12
at 202da6f0, s=48
delete 202a3
Bad channel number at 2 module 6!=5
No
InitModule_PID...t
Module Id=1 configuration parseding parameter manager info ****
at 202da7fc, s=16
at 202da45c, s=4
at 202da810, s=0
at 202da818, s=12 Try to pa
at 202da8a0, s=16
delete 202dacc8
delete 202dacd4
delete 202dace0
delete 202dacf0
delete 202dacfc
delete 202dad0c
delete 202dad18
delete 202dad28
delete 202dad34
delete 202dad44
delete 202dad50
delete 202dad60
delete 202dad6c
delete 202dad7c
delete 202dad88
delete 202dad98
delete 202dada4
delete 202dadb4
delete 202dadc0
delete 202dadd0
delete 202daddc
delete 202dade8
delete 202dab4c
зав № 10746090202015253
